maxmega
February 24, 2016, 11:08pm
1
I want to trigger a relay for 10 seconds when i push a button in blynk.
I couldn’t find something like this on internet, then i tried to make one with
[code]
timer.setInterval(8000, RelayOn);
[/code] and [code]
BLYNK_WRITE(3)
if (param.asInt()) {
if((currentMillis - previousMillis >= OnTime))
led1.on();
previousMillis = currentMillis; // Remember the time
else led1.off();
[/code] but i didn’t got it to work.
Does someting like this exist?
Thanks!
Dmitriy
February 24, 2016, 11:21pm
2
Hi. What do you mean by “trigger for 10 seconds”?
maxmega
February 24, 2016, 11:25pm
3
Thanks for your reply,
when i push the button, relay is on for 10 sec and turns off after that.
Dmitriy
February 24, 2016, 11:32pm
4
Pseudo code, but you should get the idea
int startTime = 0;
bool startRelay = false;
BLYNK_WRITE(3) {
startRelay = true;
startTime = currentMilis;
relayAction();
void relayAction() {
if (startRelay && currentMilis < startTime + 10sec ) {
//do any action with relay.
//do any action to stop relay.
startRelay = false;
Using SimpleTimer library:
#define RELAY_PIN 10;
void turnRelayOff() {
digitalWrite(RELAY_PIN, LOW);
Blynk.virtualWrite(V1, LOW);
Serial.println("Relay disabled");
BLYNK_WRITE(V1) {
Serial.println("Relay enabled");
digitalWrite(RELAY_PIN, HIGH);
timer.setTimeout(1000, turnRelayOff);
thank you!!!
will try this out, will solve several aspects!
can i put this setTimeout in any function? anywhere?
Yes, but the definition of function which you running using setTimeout must be before setTimeout
