First thanks for any help. I have looked at the examples but they do not really work for me. I have tried to set a timer but it appears not to have been set up properly.
http://twitter.com/blynk_app
Output any data on LCD widget!
App project setup:
LCD widget, switch to ADVANCED mode, select pin V1
#define TRIGGERPIN D1
#define ECHOPIN D2
char auth[] = "c48e77b790e64b05adf1ee77fb4dbb40";
char ssid[] = "";
char pass[] = "";
WidgetLCD lcd(V1);
void myTimerEvent()
Blynk.virtualWrite(V5, millis() / 3000); //was 1000
pinMode(TRIGGERPIN, OUTPUT);
pinMode(ECHOPIN, INPUT);
lcd.clear(); //Use it to clear the LCD Widget
lcd.print(0, 0, "Distance in cm"); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
// Please use timed events when LCD printintg in void loop to avoid sending too many commands
// It will cause a FLOOD Error, and connection will be dropped
timer.setInterval(5000L, myTimerEvent);
void mytimerEvent() ;{
lcd.print(0, 0, "Sump depth in cm"); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
long duration, distance;
digitalWrite(TRIGGERPIN, LOW);
delayMicroseconds(6);
digitalWrite(TRIGGERPIN, HIGH);
delayMicroseconds(14);
duration = pulseIn(ECHOPIN, HIGH);
distance = 68-(duration/2) / 29.1;
Serial.print(distance);
Serial.println("Cm");
lcd.print(7, 1, distance);
1. Search forum for similar topics
2. Check http://docs.blynk.cc and http://help.blynk.cc/
3. Add details :
⢠Hardware model + communication type. For example: Arduino UNO with Ethernet Shield
⢠Smartphone OS (iOS or Android) + version
⢠Blynk server or local server
⢠Blynk Library version
⢠Add your sketch code. â**Code should be formatted as example below.**
Simply paste your code between ``` If you don't format your code, your topic can be deleted by moderators.
```cpp
@sladecolin Am a newbie myself to both c and blynk.
Youâve declared mytimerEvent() in loop(). Why? Best to keep loop() simple. Just have blynk.run(); timer.run(); in loop(). Handle everything else outside either in setup or defined routines that are invoked by timer in the setup().
Move the set of statements that print to lcd as a call say write_sump_depth() {âŚ} . Setup this routine to be called by the timer e.g timer.setInterval(1000L, write_sump_depth); in setup().
As @Costas and @Gunner keep saying, keep the loop simple and to the bare minimum.
And in those same Blynk doc files there is a link to a simple example⌠(also found in the Sketch Builder under Push Data)
In you sketch, you assign/declare the timerâŚ
In your setup() you assign one or more timersâŚ
And each timer can call a function or âloop()â when the timer indicatesâŚ
void myTimerEvent()
for now quite happy to watch the time fly by. Added 2nd timer and it works, here is code for future users.
This example shows how value can be pushed from Arduino to
the Blynk App.
NOTE:
BlynkTimer provides SimpleTimer functionality:
http://playground.arduino.cc/Code/SimpleTimer
App project setup:
Value Display widget attached to Virtual Pin V5
char auth[] = "c22bf1d27d074a289c633996618f3239";
char ssid[] = "";
char pass[] = "";
void myTimerEvent()
void myTimerEvent2()
Blynk.virtualWrite(V6, millis() / 1000);
timer.setInterval(1000L, myTimerEvent2);
@Dharmendra_Vishwakar this is a two year old topic and @sladecolin hasnât been seen on the forum since 28th February last year.
even if is was a current topic, simply saying
isnât very helpful. Iâs a bit like posting on an automotive forum and saying âmy car wonât startâ.
If you share information about exactly what hardware you are trying to use, what steps youâve taken, what results you get when you compile and upload the code and what you see in the serial monitor then forum members may be able to assist.
