and eventualy this?
invalid user-defined conversion from ‘myTimerEvent()::__lambda0’ to ‘timer_callback {aka void (*)()}’ [-fpermissive]
What?
//#define BLYNK_PRINT Serial
BlynkTimer timer; // Announcing the timer
char auth[] = "00000000000000000"; // Blynk_Server "hostname.try"
char ssid[] = "##########";
char pass[] = "**************";
// Soil Moisture add
int val = 0; //value for storing moisture value
int soilPin = A0;//Declare a variable for the soil moisture sensor
int soilPower = 7;//Variable for Soil moisture Power
//Rather than powering the sensor through the 3.3V or 5V pins,
//we'll use a digital pin to power the sensor. This will
//prevent corrosion of the sensor as it sits in the soil.
void myTimerEvent()
digitalWrite(soilPower, HIGH);//turn D7 "On"
timer.setTimeout(10L, []() { // Lambda Timer Function
val = analogRead(soilPin);//Read the SIG value form sensor
digitalWrite(soilPower, LOW);//turn D7 "Off"
return val;//send current moisture value
}); // END
pinMode(soilPower, OUTPUT);//Set D7 as an OUTPUT
digitalWrite(soilPower, LOW);//Set to LOW so no power is flowing through the
//hostname add
Serial.printf("Default hostname: %s\n", WiFi.hostname().c_str());
WiFi.hostname("Moisture.try");
Serial.printf("New hostname: %s\n", WiFi.hostname().c_str());
Blynk.begin(auth, ssid, pass, IPAddress(***, ***, ***, ***), ****);
timer.run(); // running timer every second
You need a closing bracket on the myTimerEvent
function.
Plus I would probably ditch the return
, and just use the global variable.
void myTimerEvent()
}); // END
} //you are missing this
//hostname add
timer.setInterval(1000L, myTimerEvent); // running timer every second
ah okay great… THANKS i’ll try it asap
Okay great that worked (the second time haha)
how would you use a global variant here?
i would like to use a virtual pin so i can it working on my Blynk local server and app on phone…
I was just saying to use the variable val, instead of having it returned to the function.
If you are looking to display the value from the sensor on the app, you would just add in a virtual write.
void myTimerEvent()
// Send val to virtual pin 5 on BLYNK
Blynk.virtualWrite(V5, val);
}); // END
Should work just the same on a local server provided you have it set-up correctly.
yes that would be handy using more then one sensor…
do they work independent from each other ?
Or do timers wait for the one before it… or would i work if the first interval is longer then the one before it?
correctly i dont know?
but it works and it restarts… for now haha… i still need to google and check how certificates and what not works?
i didn’t know that this would work as easy as adding a dht22 sensor virtual write…
so check if it works on the d1mini…
and then make it bigger for the UNO WiFi R3 ATmega328P (add four sensors and so on
Thanks a million btw
You’re using a hardware device that isn’t capable of multi-tasking, so it can only perform one operation at any one time.
The Blynk/Simple timer is a non-blocking command, but the functions that you call with it can block the execution of your code. Blocking the code execution is not a good thing when using Blynk, as the Blynk library needs processor time to maintain communication with the server.
Because of this, you should try to avoid calling timed functions in a what where they will coincide with each other. Setting-up two timers that both have an interval of 2000 ms will mean that both timers try to execute at virtually the same time, and this can cause problems.
In the example I gave, both timers will coincide with each other, as 60000 is divisible by 2000.
There are several threads about different techniques for preventing timers from coinciding and if you’re having problems with missed readings, or Blynk disconnections then you should search for them and study the discussions on the subject.
