(I use RPi 3 Model BV1.2 and Thonny 3.2.0)
This tutorial should get you a basic understanding of how you can get data from the app to your rpi in a python program. I researched it as i couldn’t get the basic ‘Blynk direct to RPi physical pins’ set up to work as it was documented here.
I was expecting the following code to work on RPi, but it doesn’t :
import blynklib
import time
BLYNK_AUTH = 't7BQHE3PvBko6ql-HF_WzeO-JMsHb01-'
blynk = blynklib.Blynk(BLYNK_AUTH)
try:
blynk.run()
while True:
time.sleep(.1)
except KeyboardInterrupt:
GPIO.cleanup()
I’m looking to open a hatch via relais connected by the RPi. that’s will be the use case for this code.
Make sure you import the libraries in Thonny via menu >Tools>Manage Packages…
So this is how i get a port controlled by a button widget on the app:
create a new project with 2 button widgets. one with pin V5 and the other with pin V6
the comments in the code are in Dutch / Nederlands
import RPi.GPIO as GPIO
import time
import blynklib
#definieer variabelen
Relais=[5,6] # lijst met poort nummers van de relais, zo kunnen we alle output poorten in 1 keer instellen
#configureer de input output poorten
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(Relais,GPIO.OUT)
global valueV5
valueV5=0
global valueV6
valueV6=0
BLYNK_AUTH = 'your auth code'
# initialize Blynk
# register handler for virtual pin V5 write event
@blynk.handle_event('write V5')
def write_virtual_pin_handler(pin, value):
global valueV5
valueV5 = int(value[0])
print("V5 : ",valueV5)
# register handler for virtual pin V6 write event
@blynk.handle_event('write V6')
global valueV6
valueV6 = int(value[0])
print("V6 : ",valueV6)
try:
while True:
blynk.run()
if valueV5==1:
GPIO.output(5,GPIO.HIGH)
else:
GPIO.output(5,GPIO.LOW)
if valueV6==1:
GPIO.output(6,GPIO.HIGH)
else:
GPIO.output(6,GPIO.LOW)
GPIO.cleanup()
one comment: I read that the blynk.run() statement should not be in the While True: loop but it doesn’t work if it is not in that loop…
comments to improve/optimize are very welcome
have fun
