Hi. I communicated two ESP8266 through BLYNK BRIDGE. I did tests and everything was fine. My broad project consists of sending data from an accelerometer / gyroscope (MPU6050) to the master ESP and that it sends the data to the slave ESP to control a led strip (WS2812) and an audio card (Tsunami wav trigger). Up to this point it all works perfectly BUT when I add the virtual pins part to the App, it becomes exaggeratedly slow, it stops working as it should.
I already tried changing wifi signals. Any suggestions? please
MASTER
#include "I2Cdev.h"
#include "MPU6050.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
//new
long tiempo_prev;
float dt;
float ang_x, ang_y, ang_z;
float ang_x_prev, ang_y_prev, ang_z_prev;
char auth[] = "JHzKPO_BFl8_k_6z7We62kX6UYjxDsC6";
char ssid[] = "INFINITUM3EF9_2.4";
char pass[] = "kYX95bL3L9";
//char ssid[] = "wifi bonito";
//char pass[] = "pepepecas";
// Bridge widget on virtual pin 1
WidgetBridge bridge1(V1);
// Timer for blynking
BLYNK_CONNECTED() {
bridge1.setAuthToken("5LTsygvSwVPMC6kAOpW1HWjfnJ3tKCDh"); // Place the AuthToken of the second hardware here
Wire.begin();
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
// Inicializa el MPU6050
Serial.println("Initializing I2C devices...");
accelgyro.initialize();
// Verifica la conexiĂłn
Serial.println("Testing device connections...");
Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
timer.setInterval(10, updateFiltered);
//new
//**OFFSETS DEL MPU6050 HORIZONTAL **//
accelgyro.setXAccelOffset(-742); //-523
accelgyro.setYAccelOffset(-2806); //-2809
accelgyro.setZAccelOffset(1028); //1023
accelgyro.setXGyroOffset(48); //83 76
accelgyro.setYGyroOffset(11);//18 22
accelgyro.setZGyroOffset(9); //13
//funciĂłn para filtro complementario
void updateFiltered()
dt = (millis() - tiempo_prev) / 1000.0;
tiempo_prev = millis();
//Calcular los ĂĄngulos con acelerometro
float accel_ang_x = atan(ay / sqrt(pow(ax, 2) + pow(az, 2)))*(180.0 / 3.14);
float accel_ang_y = atan(-ax / sqrt(pow(ay, 2) + pow(az, 2)))*(180.0 / 3.14);
//Calcular angulo de rotaciĂłn con giroscopio y filtro complementario
ang_y = 0.3*(ang_y_prev + (gy / 131)*dt) + 0.7*accel_ang_y;
ang_x = 0.6*(ang_x_prev + (gz / 131)*dt) + 0.4*accel_ang_x; //NO CAMBIAR NADA, ESTĂ PERFECTO ASĂ :)
ang_x_prev = ang_x; //MOVIMIENTOS A LOS COSTADOS
ang_y_prev = ang_y; //MOVIMIENTOS FRONTALES
Serial.print("\t");
Serial.print("Rotacion en X: ");
Serial.print(ang_x_prev);
Serial.print("\t Rotacion en Y: ");
Serial.println(ang_y_prev);
//ENVĂO DE DATOS AL OTRO ESP8266
bridge1.virtualWrite(V3, ang_x_prev);
bridge1.virtualWrite(V4, ang_y_prev);
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
SLAVE
#include <Adafruit_NeoPixel.h>
#ifdef __AVR__
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
char auth [] = "5LTsygvSwVPMC6kAOpW1HWjfnJ3tKCDh";
//char ssid[] = "INFINITUM3EF9_2.4";
//char pass[] = "kYX95bL3L9";
int brillo;
int lastvalxmap;
int valX; //inclinacion en x
int valY; //inclinacion en z
int valxmap; //valor mapeado
int valxmapabs;
int valymap; //valor mapeado
int valymapabs;
//variables para cambio de color
int R;
int G;
int B;
//**************************TSUNAMI**************************************
#define TSUNAMI_NUM_OUTPUTS 8
#define CMD_TRACK_CONTROL 3
#define CMD_STOP_ALL 4
#define CMD_MASTER_VOLUME 5
#define CMD_TRACK_VOLUME 8
#define CMD_TRACK_FADE 10
#define CMD_SET_INPUT_MIX 15
#define CMD_SET_MIDI_BANK 16
#define TRK_PLAY_SOLO 0
#define TRK_PLAY_POLY 1
#define TRK_PAUSE 2
#define TRK_RESUME 3
#define TRK_STOP 4
#define TRK_LOOP_ON 5
#define TRK_LOOP_OFF 6
#define TRK_LOAD 7
#define SOM1 0xf0
#define SOM2 0xaa
#define EOM 0x55
#define IMIX_OUT1 0x01
#define IMIX_OUT2 0x02
#define IMIX_OUT3 0x04
#define IMIX_OUT4 0x08
uint16_t numTracks;
uint8_t numVoices;
uint8_t rxCount;
uint8_t rxLen;
bool rxMsgReady;
bool versionRcvd;
bool sysinfoRcvd;
//PINES TIRA LED***********************************************************
#define PIN D2 //pin del esp8266 IZQUIERDA
#define PIN2 D5 //DERECHA
#define NUMPIXELS 22 // 22 chips que controlan 3 leds cada uno. 66 leds en total
//PINES TSUNAMI************************************************************
const byte txpin = 2; //D4 pin transmisor
const byte rxpin = 5; //D1 pin receptor
SoftwareSerial tsunami(rxpin, txpin); // Crea un objeto para la trasmision serial
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_BRG + NEO_KHZ800); //configuraciĂłn tira led tipo BRG
Adafruit_NeoPixel pixels2(NUMPIXELS, PIN2, NEO_BRG + NEO_KHZ800); //configuraciĂłn tira led tipo BRG
//******CONNECTED*****************
/*BLYNK_CONNECTED() {
//Blynk.syncVirtual(V);
Blynk.syncVirtual(V3, V4);
BLYNK_WRITE (V3) {
valX = param.asInt (); //RECIBE ANGULO X
// Serial.println(valX); OK
//***MAPEO DE LOS VALORES DE LA WAV TRIGGER***// 21*4=84
valxmap = valX;
valxmap = map(valxmap, 0.00, 84.00, 0.00, 66.00);
// Serial.println(valxmap);
//Para casos de valores negativos:
valxmapabs = abs(lastvalxmap);
BLYNK_WRITE (V4) {
valY = param.asInt (); //RECIBE ANGULO Y
valymap = valY;
valymap = map(valymap, 0.00, 84.00, 0.00, 240.00);
//Serial.print("anguloY");
//Serial.println(valY);
brillo = (abs(valymap)+15);
BLYNK_WRITE(V6) {
switch (param.asInt())
case 1: // Item 1
Serial.println("color rojo");
B = 255;
R = 0;
G= 0;
break;
case 2: // Item 2
Serial.println("color azul");
B = 0;
R = 255;
G= 0;
break;
case 3:
Serial.println("color verde");
B = 0;
R = 0;
G= 255;
break;
case 4:
Serial.println("color amarillo");
B = 255;
R = 0;
G= 255;
break;
case 5:
Serial.println("color morado");
B = 87;
R = 100;
G= 35;
break;
case 6:
Serial.println("color naranja");
B = 255;
R = 0;
G= 128;
break;
case 7:
Serial.println("color rosa");
B = 255;
R = 128;
G= 0;
break;
void setup () {
Serial.begin (115200);
Blynk.begin (auth, ssid, pass);
tsunami.begin(9600);
//Temporizadores de funciones
timer.setInterval(10, luces);
//***INICIALIZACIĂN DE LA TIRA LED***//
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
clock_prescale_set(clock_div_1);
#endif
pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
pixels2.begin();
pixels.clear();
pixels2.clear();
//*******************LUZ Y SONIDO**********************************
void luces(){
if(valxmap == 0){
pixels.clear();
pixels2.clear();
//DERECHA
if (valxmap > 0) {
clearizquierda();
if (valxmap != lastvalxmap) {
lastvalxmap = valxmap;
for( int a = lastvalxmap; a <= NUMPIXELS; a++){
pixels.setPixelColor(a, pixels.Color(0, 0, 0)); //NADA
}//for para "limpiar" el color
for( int b = 0; b < lastvalxmap; b++){
pixels.setPixelColor(b, pixels.Color(B, R, G)); //VERDE
pixels.setBrightness(brillo); //brillo de los leds basado en movimiento adelante
}//for para asignar color
pixels.show();
trackPlayPoly(valxmapabs, 3, true); //BOCINA CABEZA DERECHA 0
//trackGain(valxmapabs, 5);
// tsunami.trackFade(2, 0, 2000, false); // Fade Track 2 to 0dB over 2 sec
}// final if DERECHA
//IZQUIERDA
if (valxmap < 0) {
clearderecha();
for( int a = valxmapabs; a <= NUMPIXELS; a++){
pixels2.setPixelColor(a, pixels2.Color(0, 0, 0)); //NADA
for( int b = 0; b < valxmapabs; b++){
pixels2.setPixelColor(b, pixels2.Color(B, R, G)); //VERDE
pixels2.setBrightness(brillo); //brillo de los leds basado en movimiento atrĂĄs
pixels2.show();
trackPlayPoly(valxmapabs, 1, true); //BOCINA CABEZA IZQUIERDA 4
// trackGain(valxmapabs, 5);
}// final if IZQUIERDA
void clearderecha(){
for( int e = lastvalxmap; e <= NUMPIXELS; e++){
pixels.setPixelColor(e, pixels.Color(0, 0, 0)); //NADA
pixels.show();
}//final void1
void clearizquierda(){
pixels2.setPixelColor(e, pixels2.Color(0, 0, 0)); //NADA
pixels2.show();
}//final void2
//**************************CONTROL*******************************************
void trackControl(int trk, int code, int out, int flags) {
uint8_t txbuf[10];
uint8_t o;
o = out & 0x07;
txbuf[0] = SOM1;
txbuf[1] = SOM2;
txbuf[2] = 0x0a;
txbuf[3] = CMD_TRACK_CONTROL;
txbuf[4] = (uint8_t)code;
txbuf[5] = (uint8_t)trk;
txbuf[6] = (uint8_t)(trk >> 8);
txbuf[7] = (uint8_t)o;
txbuf[8] = (uint8_t)flags;
txbuf[9] = EOM;
tsunami.write(o);
tsunami.write(SOM1);
tsunami.write(SOM2);
tsunami.write(0x0a);
tsunami.write(CMD_TRACK_CONTROL);
tsunami.write((uint8_t)code);
tsunami.write((uint8_t)trk);
tsunami.write((uint8_t)(trk >> 8));
tsunami.write((uint8_t)o);
tsunami.write((uint8_t)flags);
tsunami.write(EOM);
//***************************POLY**********************************************
void trackPlayPoly(int trk, int out, bool lock) {
int flags = 0;
if (lock)
flags |= 0x01;
trackControl(trk, TRK_PLAY_POLY, out, flags);
//***************************GAIN**********************************************
void trackGain(int trk, int gain) {
uint8_t txbuf[9];
unsigned short vol;
txbuf[0] = SOM1;
txbuf[1] = SOM2;
txbuf[2] = 0x09;
txbuf[3] = CMD_TRACK_VOLUME;
txbuf[4] = (uint8_t)trk;
txbuf[5] = (uint8_t)(trk >> 8);
vol = (unsigned short)gain;
txbuf[6] = (uint8_t)vol;
txbuf[7] = (uint8_t)(vol >> 8);
txbuf[8] = EOM;
//****************************LOOP********************************************
void loop () {
Blynk.run ();
