Blynk stepper motor
thanks
hello, I want to add a limit switch to stop the code I wrote, but I couldn’t succeed, can you help me?
#include <Stepper.h> // Include the header file
// change this to the number of steps on your motor
#define STEPS 64
// create an instance of the stepper class using the steps and pins
Stepper stepper(STEPS, D0, D7, D6, D5);
char auth[] = "BXJHLmqGmwlUF8WZuTHBrdhpGYpvZAdG";
char ssid[] = "AirTies_Air5650_7GD7";
char pass[] = "123onr456";
//Run the program only after opening the blinds
boolean closed = false;
boolean opened = true;
void disable_motor() //turn off the motor when done to avoid heating
  digitalWrite(D1,LOW);
  digitalWrite(D2,LOW);
  digitalWrite(D3,LOW);
  digitalWrite(D4,LOW);
  pinMode(D0, OUTPUT); //on-board LED as output
  digitalWrite(D0,HIGH); //turn this light on
  stepper.setSpeed(500);
  //http://188.166.206.43/l_b47mF1hioCc_7FzdKMJJeFnJjxxxx_/update/V1?value=1 /
  digitalWrite(D0,LOW); //turn it off after connecting to blynk
BLYNK_WRITE(V1) //CLOSE the BLINDS
    Serial.println("Closing Blinds");
    if (opened == true)
    for (int c_val = 0; c_val <= 130; c_val++) //rotate in Counter-Clockwise for closing
      stepper.step(c_val);
      yield();
    closed = true;
    opened = false;
    disable_motor(); // always desable stepper motors after use to reduce power consumption and heating
  BLYNK_WRITE(V2) // OPEN the BLINDS
    Serial.println("Opening Blinds");
    if (closed == true)
    for (int cc_val = 0; cc_val >= -130; cc_val--) //rotate in Clockwise for opening
      stepper.step(cc_val);
      yield();
    opened = true;
    closed = false;
I’ve moved your latest topic into this one, as they are clearly related.
Lif you look back through this topic you’ll see a theme - lack of information from you about what the overall, project is trying to achieve, and lack of detail about the areas where you are seeking assistance. Your latest post is no different.
This is why you are still looking for the same assistance one month later. I’d suggest that you attempt to elaborate on the small amount of 8nformation you require, or I think you’ll still be asking the same questions in another month’s time.
Also, this is a Blynk Legacy sketch. Are you aware that Blynk Legacy will stop working altogether in 67 days?
What will happen after 68 days, what is the plan, why will it be closed?
