Blynk Status Widget
Is there a way to poll the blynk connection for a heartbeat? As I debug my project I sometimes can’t use the Serial output window and it would be nice to put the status out to an LED. Is there a status/heartbeat variable in the blynk object I can poll for this?
To clarify, I realize that this info is not available to the remote app until the device is connected. Essentially, whta I want is something that I can poll when the “ready” message is displayed. …and possibly light an LED with some sort of heartbeat.
Edit:
Duh… I think I just answered my own question. Someone hit me with the dumb stick pls… I can just do an Blynk event and trigger it when it get’s past the connection bit…
It looks like this may help you?
 bool connect()
        <bunch of code truncated)
        return true;
(from BlynkSocket.h)
so you could monitor that for your logic on “what next”
if that wasnt clear here is a quick example (using LED widget on V1)
WidgetLED led1(1);
  Blynk.begin(auth);
  if (Blynk.connect()) {
      led1.on();
Thx, will give it a try tomorrow.
Tried this. However, it only initiates a connection and sets the LED. I am using the Adafruit CC3000. Is there a way to poll the Blynk connection on a regular basis to see if the connection is still up? I’ve had cases where the connection / CC3000 hangs and I would like to catch this, and re-initiate a connection.
Guys, we already have this feature request.
Currently it is not easy to check the status, but we will add this. Also, sometimes when CC3000 hangs, we cannot know this reliably.
Thanks!
