Hi there guys,
I have been struggling for a while now with setting up my own Blynk Server.
My Blynk Server is setup on a VPS but I keep getting the SSL not authorized error. I’ve been trying to fix this for ages but I am all out of ideas.
I have set my server.properties logging to DEBUG and I will paste the log down below.
Other than Blynk I am also running Apache2.4 and Gitlab, but that should not matter.
From my computer I run the following nodeJS program:
#!/usr/bin/env node
var blynkToken = '.....';
//Setup blynk
var Blynk = require('blynk-library');
var blynk = new Blynk.Blynk(blynkToken,
options= { addr:"mydomain.com", port:8441 }
var v0 = new blynk.VirtualPin(0);
blynk.on('connect', function() { console.log("Blynk ready."); });
The output from this program is:
Connecting to: mydomain.nl 8441
SSL authorization...
SSL not authorized
And for the Blynk server logs:
2017-04-11 15:00:03.779 DEBUG- Unpacking : static/js/login.js
2017-04-11 15:00:03.780 DEBUG- Unpacking : static/css/ng-admin.min.css
2017-04-11 15:00:03.826 DEBUG- Unpacking : static/js/admin.js
2017-04-11 15:00:03.826 DEBUG- Unpacking : static/js/enc-base64-min.js
2017-04-11 15:00:03.826 DEBUG- Unpacking : static/js/ng-admin.min.js
2017-04-11 15:00:03.863 DEBUG- Unpacking : static/js/core-min.js
2017-04-11 15:00:03.863 DEBUG- Unpacking : static/js/jquery-2.2.2.min.js
2017-04-11 15:00:03.865 DEBUG- Unpacking : static/reset/enterNewPassword.html
2017-04-11 15:00:03.908 DEBUG- Unpacking : static/js/sha256-min.js
2017-04-11 15:00:03.908 DEBUG- Unpacking : static/css/blynk.css
2017-04-11 15:00:03.908 DEBUG- Unpacking : static/login.html
2017-04-11 15:00:03.909 DEBUG- Unpacking : static/reset/site.css
2017-04-11 15:00:03.975 DEBUG- Unpacking : static/js/bootstrap.min.js
2017-04-11 15:00:03.976 DEBUG- Unpacking : static/admin.html
2017-04-11 15:00:03.977 DEBUG- Unpacking : static/favicon.ico
2017-04-11 15:00:04.013 DEBUG- Unpacking : static/reset/reset-email.html
2017-04-11 15:00:04.088 INFO - Using data dir '.'
2017-04-11 15:00:04.104 DEBUG- Using SLF4J as the default logging framework
2017-04-11 15:00:04.105 DEBUG- -Dio.netty.noUnsafe: false
2017-04-11 15:00:04.106 DEBUG- java.nio.Buffer.address: available
2017-04-11 15:00:04.107 DEBUG- sun.misc.Unsafe.theUnsafe: available
2017-04-11 15:00:04.107 DEBUG- sun.misc.Unsafe.copyMemory: available
2017-04-11 15:00:04.107 DEBUG- direct buffer constructor: available
2017-04-11 15:00:04.108 DEBUG- java.nio.Bits.unaligned: available, true
2017-04-11 15:00:04.108 DEBUG- java.nio.DirectByteBuffer.<init>(long, int): available
2017-04-11 15:00:04.109 DEBUG- java.nio.ByteBuffer.cleaner(): available
2017-04-11 15:00:04.109 DEBUG- Java version: 8
2017-04-11 15:00:04.109 DEBUG- sun.misc.Unsafe: available
2017-04-11 15:00:04.109 DEBUG- -Dio.netty.noJavassist: false
2017-04-11 15:00:04.242 DEBUG- Javassist: available
2017-04-11 15:00:04.243 DEBUG- -Dio.netty.tmpdir: /tmp (java.io.tmpdir)
2017-04-11 15:00:04.243 DEBUG- -Dio.netty.bitMode: 64 (sun.arch.data.model)
2017-04-11 15:00:04.243 DEBUG- -Dio.netty.noPreferDirect: false
2017-04-11 15:00:04.243 DEBUG- io.netty.maxDirectMemory: 921174016 bytes
2017-04-11 15:00:04.245 DEBUG- Starting reading user DB.
2017-04-11 15:00:04.599 DEBUG- Reading user DB finished.
2017-04-11 15:00:04.599 INFO - Region : local
2017-04-11 15:00:04.610 DEBUG- -Dio.netty.eventLoopThreads: 4
2017-04-11 15:00:04.626 DEBUG- -Dio.netty.noKeySetOptimization: false
2017-04-11 15:00:04.626 DEBUG- -Dio.netty.selectorAutoRebuildThreshold: 512
2017-04-11 15:00:04.627 DEBUG- org.jctools-core.MpscChunkedArrayQueue: available
2017-04-11 15:00:04.878 DEBUG- Default protocols (JDK): [TLSv1.2, TLSv1.1, TLSv1]
2017-04-11 15:00:04.878 DEBUG- Default cipher suites (JDK): [TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_128_GCM_SH$
2017-04-11 15:00:04.900 DEBUG- -Dio.netty.leakDetection.level: simple
2017-04-11 15:00:04.900 DEBUG- -Dio.netty.leakDetection.maxRecords: 4
2017-04-11 15:00:04.900 DEBUG- Loaded default ResourceLeakDetector: io.netty.util.ResourceLeakDetector@2b72cb8a
2017-04-11 15:00:04.905 DEBUG- -Dio.netty.initialSeedUniquifier: 0x1f881e26407bfdce
2017-04-11 15:00:04.950 DEBUG- -Dio.netty.allocator.numHeapArenas: 4
2017-04-11 15:00:04.950 DEBUG- -Dio.netty.allocator.numDirectArenas: 4
2017-04-11 15:00:04.950 DEBUG- -Dio.netty.allocator.pageSize: 8192
2017-04-11 15:00:04.950 DEBUG- -Dio.netty.allocator.maxOrder: 11
2017-04-11 15:00:04.951 DEBUG- -Dio.netty.allocator.chunkSize: 16777216
2017-04-11 15:00:04.951 DEBUG- -Dio.netty.allocator.tinyCacheSize: 512
2017-04-11 15:00:04.951 DEBUG- -Dio.netty.allocator.smallCacheSize: 256
2017-04-11 15:00:04.951 DEBUG- -Dio.netty.allocator.normalCacheSize: 64
2017-04-11 15:00:04.951 DEBUG- -Dio.netty.allocator.maxCachedBufferCapacity: 32768
2017-04-11 15:00:04.951 DEBUG- -Dio.netty.allocator.cacheTrimInterval: 8192
2017-04-11 15:00:04.951 DEBUG- -Dio.netty.allocator.useCacheForAllThreads: true
2017-04-11 15:00:04.959 DEBUG- -Dio.netty.allocator.type: pooled
2017-04-11 15:00:04.959 DEBUG- -Dio.netty.threadLocalDirectBufferSize: 65536
2017-04-11 15:00:04.959 DEBUG- -Dio.netty.maxThreadLocalCharBufferSize: 16384
2017-04-11 15:00:05.009 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
2017-04-11 15:00:05.033 DEBUG- Generated: io.netty.util.internal.__matchers__.cc.blynk.server.core.protocol.model.messages.appllication.LoginMessageMatcher
2017-04-11 15:00:05.034 DEBUG- hard.socket.idle.timeout = 15
2017-04-11 15:00:05.055 DEBUG- -Dio.netty.buffer.bytebuf.checkAccessible: true
2017-04-11 15:00:05.055 DEBUG- Loaded default ResourceLeakDetector: io.netty.util.ResourceLeakDetector@39655d3e
2017-04-11 15:00:05.098 DEBUG- Generated: io.netty.util.internal.__matchers__.cc.blynk.server.core.protocol.model.messages.appllication.RegisterMessageMatcher
2017-04-11 15:00:05.101 DEBUG- Generated: io.netty.util.internal.__matchers__.cc.blynk.server.core.protocol.model.messages.appllication.sharing.ShareLoginMessageMatcher
2017-04-11 15:00:05.104 DEBUG- Generated: io.netty.util.internal.__matchers__.cc.blynk.server.core.protocol.model.messages.MessageBaseMatcher
2017-04-11 15:00:05.109 DEBUG- Generated: io.netty.util.internal.__matchers__.cc.blynk.server.core.protocol.model.messages.appllication.GetServerMessageMatcher
2017-04-11 15:00:05.109 WARN - Found server certificates but no client certificate for '/home/fdekruijff/Blynk' path. Using one way ssl.
2017-04-11 15:00:05.123 DEBUG- app.socket.idle.timeout = 600
2017-04-11 15:00:05.210 DEBUG- Generated: io.netty.util.internal.__matchers__.io.netty.handler.codec.mqtt.MqttConnectMessageMatcher
2017-04-11 15:00:05.210 DEBUG- hard.socket.idle.timeout = 15
2017-04-11 15:00:05.220 DEBUG- -Dio.netty.processId: 29246 (auto-detected)
2017-04-11 15:00:05.221 DEBUG- -Djava.net.preferIPv4Stack: false
2017-04-11 15:00:05.221 DEBUG- -Djava.net.preferIPv6Addresses: false
2017-04-11 15:00:05.222 DEBUG- Loopback interface: lo (lo, 0:0:0:0:0:0:0:1%lo)
2017-04-11 15:00:05.225 DEBUG- /proc/sys/net/core/somaxconn: 1024
2017-04-11 15:00:05.226 WARN - Failed to find a usable hardware address from the network interfaces; using random bytes: 5b:df:a0:6c:ab:60:06:23
2017-04-11 15:00:05.228 DEBUG- -Dio.netty.machineId: 5b:df:a0:6c:ab:60:06:23 (auto-detected)
2017-04-11 15:00:05.250 INFO - Hardware plain tcp/ip server listening at 8442 port.
2017-04-11 15:00:05.250 INFO - Hardware SSL server listening at 8441 port.
2017-04-11 15:00:05.251 INFO - Application server listening at 8443 port.
2017-04-11 15:00:05.251 INFO - HTTP API and WebSockets server listening at 8081 port.
2017-04-11 15:00:05.251 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
2017-04-11 15:00:05.252 INFO - Mqtt hardware server listening at 8440 port.
2017-04-11 15:00:10.373 DEBUG- -Dio.netty.recycler.maxCapacityPerThread: 32768
2017-04-11 15:00:10.373 DEBUG- -Dio.netty.recycler.maxSharedCapacityFactor: 2
2017-04-11 15:00:10.373 DEBUG- -Dio.netty.recycler.linkCapacity: 16
2017-04-11 15:00:10.374 DEBUG- -Dio.netty.recycler.ratio: 8
2017-04-11 15:00:10.523 DEBUG- [id: 0x42a5235b, L:/136.144.139.191:8441 - R:/149.210.210.210:43115] HANDSHAKEN: TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
Things that I noticed where that it fails to find an hardware address.
It also found the server certificate, the same ones I use for Apache, but I did not specify client certificates.
And when I leave the certificates blank the same error occurs.
I hope someone can help me with this issue, I’d be really grateful!
Floris
