Blynk-ser.sh start arduno pin high :(
I use arduino by usb, in armbian, when running the blynk-ser.sh script, gpio is set to high. This only happens when the blynk-ser.sh script is run.
How to prevent my relay from turning on when the script loads?
DebugSerial.begin(9600);
pinMode(7, OUTPUT);
digitalWrite(7, LOW);
Blynk.begin(Serial, auth);
It does not help…
Have you tried moving the digitalWrite so that it’s immediately after the Blynk.begin command?
The same thing happens. Start on high.
pinMode(7, OUTPUT);
if you change the input to output
pinMode(7, INPUT);
In this case, short-term activation occurs.
It is very simple but I can not figure it out :frowning:
This happens after the start of Blynk-ser.sh, maybe need to change something in it …
