Blynk running on Particle Photon
Add details :
• Hardware model + communication type: Particle Photon
• Smartphone OS: Latest Android
• Blynk server region: Sydney, Australia - so I guess that means sgp1 - Singapore
• Blynk Library version : Not sure
Hi, I’m struggling getting Blynk running on a Particle Photon. I’ve been following this tutorial. I think you need a Blynk cloud account to see it.
I’ve got everything all hooked up and online. But I think the code I’ve flashed to the Particle Photon might be totally inappropriate - attached at bottom of post.
I flashed an ESP8266 many years ago with Blynk server and downloaded the Blynk app, assigned some pin numbers and everything just worked.
So I’m not 100% what I’ve screwed up but I suspect it’s the Blynk code/template from the tutorial.
I’ve got the Photon plugged into a Particle relay board and will ultimately be flipping pins D3, D4, D5 and D6 to trigger those relays.
Any help would be much appreciated. Thanks.
#include "Particle.h"
// *** MAIN SETTINGS ***
// Replace this block with correct template settings.
// You can find it for every template here:
//   https://blynk.cloud/dashboard/templates
#define BLYNK_TEMPLATE_ID "TMPL6D6Yf97Bw"
#define BLYNK_TEMPLATE_NAME "Connect a Particle device"
#define BLYNK_AUTH_TOKEN "xxx"
const char *firmware_version = "0.0.0";
#include <math.h> // This library is only for function simulating a sensor
double v15 = 3.14159;
uint32_t simSensor_timer_last = 0; // This is a variable for a function that simulates a sensor
uint8_t led_state = LOW;
bool particle_fn_called = TRUE; // causes the device to publish data immediately after started/boot and connected to the Particle cloud.
// Register the Particle cloud function
int blynkLED(String on_or_off);
inline
float approx_cos(float x)
  constexpr float tp = 1.0/(2.0*M_PI);
  x *= tp;
  x -= 0.25f + floor(x + 0.25f);
  x *= 16.0f * (abs(x) - 0.5f);
  x += 0.225f * x * (abs(x) - 1.0f);
  return x;
void simSensor()    //This function simulates a sensor
  long sim = random(millis());
  if (millis() - simSensor_timer_last >= 20000) {
    simSensor_timer_last = millis();
    float deltaSensor = approx_cos(float(sim) / 1000) / 100;
       if (v15 <= 0 || v15 >= 3.3)
      v15 = v15 - deltaSensor;
      v15 = v15 + deltaSensor;
} // simSensor
bool deviceHasLedOnD7()
  // Returns TRUE if the device has a built-in LED on D7:
  //  Boron, Argon, Photon 2, Photon, Electron, Core
  // 8: P1
  switch (PLATFORM_ID)
  case PLATFORM_BORON:
  case PLATFORM_ARGON:
  case 0:  // Core
  case 6:  // Photon  (PLATFORM_PHOTON_PRODUCTION)
  case 10: // Electron  (PLATFORM_ELECTRON_PRODUCTION)
    return TRUE;
  default:
    return FALSE;
} // deviceHasLedOnD7()
// Timer
const uint32_t TIMER_INTERVAL_MS = 300000L;
uint32_t timer_last = 0;
void pubToParticleBlynk()
  if (Particle.connected())
    char data[128];
    snprintf(data, sizeof(data),
                 R"json({"t":"%s","v14":"%u","v15":"%f","v16":"%u","v17":"%u"})json",
                 BLYNK_AUTH_TOKEN, millis(), v15, led_state, led_state);
    Serial.printlnf("Sending to Blynk: '%s' with size of %u bytes", data, strlen(data));
    bool pub_result = Particle.publish("blynk_https_get", data, PRIVATE);
    if (pub_result)
      Serial.println("ERROR: Particle.publish()");
} // pubToParticleBlynk()
void pubTimer()
  // A timer for publishing data to Particle Cloud, and then continuing to Blynk.
  if (timer_last > millis())
  if ((millis() - timer_last) > TIMER_INTERVAL_MS && Particle.connected())
    pubToParticleBlynk();
} // pubTimer()
  if (deviceHasLedOnD7() == TRUE)
    pinMode(D7, OUTPUT);
    digitalWrite(D7, LOW);
  waitFor(Serial.isConnected, 5000);
  Serial.printlnf("Device OS v%s", System.version().c_str());
  Serial.printlnf("Free RAM %lu bytes", System.freeMemory());
  Serial.printlnf("Firmware version v%s", firmware_version);
  // register the Particle cloud function (funcKey, funcName)
  Particle.function("blynk_led", blynkLED);
  Serial.println("Setup complete");
} // setup()
  simSensor(); // This is function simulates a sensor
  pubTimer();
  if (particle_fn_called == TRUE)
    particle_fn_called = FALSE;
    // Publish data to Particle cloud..
    digitalWrite(D7, led_state);
} // loop()
int blynkLED(String on_off)
  // Custom Particle cloud function that changes the state of the built-in LED
  // on D7 in response to an instruction from Blynk calling this
  // custom cloud function.
  // Returns the value 1 if the LED has been turned on, and 0 if turned off,
  // -1 if an unexpected on_off value is received.
  // Cloud functions must return int and take one String argument
  // curl https://api.particle.io/v1/devices/{your 25 char device id}/blynk_led
  // -d access_token={your 40 char access token}
  // -d "args=on/off"
  if (on_off == "on" || on_off == "1")
    led_state = HIGH;
    return 1;
  else if (on_off == "off" || on_off == "0")
    led_state = LOW;
    return 0;
    Serial.print("Unexpected on_off value of: '");
    Serial.print(on_off);
    Serial.println("'");
  return -1;
} // blynkLED()
anyone?
