Blynk restart problem Raspberry Pi
Hello everyone,
I made a hayfeeder for horses for my integrated test for school. This project use blynk but when i start the program it runs 5 minutes and then disconnect.
I have ride a block that check the blynk connection.When the connection is lost it do a full blynk restart. But then he is doing it over and over again.
This block check the connection:
def blynk_verbinding_controlleren():
print(“blynk_verbinding_controlleren”)
returnV5=blynk.virtual_sync(5)
if returnV5==9:
print(time.asctime(time.localtime(time.time())),“De blynkverbinding is oke.”)
else:
print(time.asctime(time.localtime(time.time())),“De blynkverbinding is verbroken.”)
full_blynk_restart()
This block does a full blynk restart:
def full_blynk_restart():
wachten(10)
blynk = blynklib.Blynk(BLYNK_AUTH)
blynk.run()
wachten(2)
blynk.virtual_write(63, 20)
wachten(2)
blynk.virtual_write(63, 0)
print(time.asctime( time.localtime(time.time())),‘Blynk-verbinding is gereset.’)
My full program:
import RPi.GPIO as GPIO
import time
import blynklib
import datetime
import schedule
import random
import Adafruit_DHT
BLYNK_AUTH = ‘DDaU4NGfV9i5wuZ4UK3HHBVVYzXqA4Td’ #auth Arno
#BLYNK_AUTH = ‘t7BQHE3PvBko6ql-HF_WzeO-JMsHb01-’ #auth Tom
LS1port=23
LS2port=24
LS3port=4
LS4port=17
LS5port=27
LSlist=[LS1port,LS2port,LS3port,LS4port,LS5port]
Luik1port=12
Luik2port=16
Luik3port=20
Luik4port=21
Luik5port=26
Waarschuwingsport=19
Relais=(12, 16, 20, 21, 26, 19)
Tellerwaarschuwing=5
StatusV15 = 0
StatusV16 = 0
StatusV17 = 0
global notificatie
notificatie = 1
global waardeV1
waardeV1=0
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(LSlist,GPIO.IN,pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(Relais,GPIO.OUT)
#blynk = blynklib.Blynk(BLYNK_AUTH, server=‘blynk-cloud.com’, port=80, heartbeat=10, rcv_buffer=1042, log=print)
BlynkReadTimeOut=1
def wachten(sec):
secteller=sec
while secteller>0:
blynk.run()
secteller=secteller-1
msecteller=0
while msecteller<10:
msecteller=msecteller+1
time.sleep(0.1)
def meet_TenH():
blynk.run()
localtime = time.asctime( time.localtime(time.time()) )
humidity, temperature = Adafruit_DHT.read_retry(Adafruit_DHT.DHT22, 10)
blynk.virtual_write(60, int(temperature))
blynk.virtual_write(61, int(humidity))
print(localtime," t=",int(temperature),“C h=”,int(humidity),"%")
def double_digit_string(tijd): #functie om elk uur of min om te vormen in een 2 character string
if tijd<10:
tijd=“0”+str(tijd)
else:
tijd=str(tijd)
return tijd
@blynk.handle_event(‘write V1’) #manueel volgende luik bedienen
def write_virtual_pin_handlerV1(pin, value):
print(time.asctime( time.localtime(time.time())),‘write_virtual_pin_handlerV1:’, value)
global waardeV1
waardeV1 = int(value[0])
if waardeV1==1:
print(‘waarde =’, value)
volgendluikbedienen()
waardeV1=0
@blynk.handle_event(‘write V5’) # button voor notificaties aan/uit
def write_virtual_pin_handlerV5(pin,value):
print(time.asctime( time.localtime(time.time())),‘write_virtual_pin_handlerV5:’, int(value[0]))
global notificatie
if int(value[0])==1:
notificatie=True
print(“notificatie aan :”,notificatie)
else:
notificatie=False
print(“notificatie uit :”,notificatie)
@blynk.handle_event(‘write V31’) # ophalen uur voederbeurt 1
def write_virtual_pin_handler31(pin, value):
schedule.clear(‘voederbeurt31’)
global Uur1
global Min1
if value[0] == “”:
print(time.asctime( time.localtime(time.time())),“Geen uur ingesteld”)
else:
#print(time.asctime( time.localtime(time.time())),‘write_virtual_pin_handlerV21:’, value)
global waardeV31
Seconden = int(value[0])
Uur1 = Seconden // 3600
Min1 = (Seconden-(Uur1*3600))//60
Voederbeurttijdstip31 = double_digit_string(Uur1) + “:” + double_digit_string(Min1) +":00"
schedule.every().day.at(Voederbeurttijdstip31).do(voederuur_controleren_en_bedienen).tag(“Voederbeurt31”)
print(time.asctime( time.localtime(time.time())),‘Tijdstip V31’, Voederbeurttijdstip31)
@blynk.handle_event(‘write V32’) # ophalen uur voederbeurt 2
def write_virtual_pin_handler32(pin, value):
schedule.clear(‘voederbeurt32’)
global Uur2
global Min2
if value[0] == “”:
else:
#print(time.asctime( time.localtime(time.time())),‘write_virtual_pin_handlerV32:’, value)
global waardeV32
Uur2 = Seconden // 3600
Min2 = (Seconden-(Uur2*3600))//60
Voederbeurttijdstip32 = double_digit_string(Uur2) + “:” + double_digit_string(Min2) +":00"
schedule.every().day.at(Voederbeurttijdstip32).do(voederuur_controleren_en_bedienen).tag(“voederbeurt32”)
print(time.asctime( time.localtime(time.time())),‘Tijdstip V32’, Voederbeurttijdstip32)
@blynk.handle_event(‘write V33’) # ophalen uur voederbeurt 3
def write_virtual_pin_handler33(pin, value):
schedule.clear(‘voederbeurt33’)
global Uur3
global Min3
if value[0] == “”:
else:
#print(time.asctime( time.localtime(time.time())),‘write_virtual_pin_handlerV33:’, value)
global waardeV33
Uur3 = Seconden // 3600
Min3 = (Seconden-(Uur3*3600))//60
Voederbeurttijdstip33 = double_digit_string(Uur3) + “:” + double_digit_string(Min3) +":00"
schedule.every().day.at(Voederbeurttijdstip33).do(voederuur_controleren_en_bedienen).tag(“voederbeurt33”)
print(time.asctime( time.localtime(time.time())),‘Tijdstip V33’, Voederbeurttijdstip33)
@blynk.handle_event(‘write V34’) # ophalen uur voederbeurt 4
def write_virtual_pin_handler34(pin, value):
schedule.clear(‘voederbeurt34’)
global Uur4
global Min4
if value[0] == “”:
else:
#print(time.asctime( time.localtime(time.time())),‘write_virtual_pin_handlerV34:’, value)
global waardeV34
Uur4 = Seconden // 3600
Min4 = (Seconden-(Uur4*3600))//60
Voederbeurttijdstip34 = double_digit_string(Uur4) + “:” + double_digit_string(Min4) +":00"
schedule.every().day.at(Voederbeurttijdstip34).do(voederuur_controleren_en_bedienen).tag(“voederbeurt34”)
print(time.asctime( time.localtime(time.time())),‘Tijdstip V34’, Voederbeurttijdstip34)
@blynk.handle_event(‘write V35’) # ophalen uur voederbeurt 5
def write_virtual_pin_handler35(pin, value):
schedule.clear(‘voederbeurt35’)
global Uur5
global Min5
if value[0] == “”:
else:
#print(time.asctime( time.localtime(time.time())),‘write_virtual_pin_handlerV35:’, value)
global waardeV35
Uur5 = Seconden // 3600
Min5 = (Seconden-(Uur5*3600))//60
Voederbeurttijdstip35 = double_digit_string(Uur5) + “:” + double_digit_string(Min5) +":00"
schedule.every().day.at(Voederbeurttijdstip35).do(voederuur_controleren_en_bedienen).tag(“voederbeurt35”)
print(time.asctime( time.localtime(time.time())),‘Tijdstip V35’, Voederbeurttijdstip35)
def relaissturen(relaispin):
blynk.run()
i = Tellerwaarschuwing
while i > 0:
i = i - 1
GPIO.output(Waarschuwingsport,GPIO.HIGH)
time.sleep(0.2)
GPIO.output(Waarschuwingsport,GPIO.LOW)
time.sleep(0.2)
GPIO.output(relaispin,GPIO.HIGH)
print("relais",relaispin,"aan")
blynk.virtual_write(62, 20)
wachten(1)
GPIO.output(relaispin,GPIO.LOW)
print("relais ",relaispin," uit")
blynk.virtual_write(62, 0)
def volgendluikbedienen():
print(time.asctime( time.localtime(time.time())),‘start volgend luik bedienen’)
wachten(1)
if GPIO.input(LS1port):
print(time.asctime( time.localtime(time.time())),“Volgendeluikbedienen gedrukt”)
relaissturen(Luik1port)
if notificatie:
blynk.notify(“Luik 1 is geopend.”)
else:
if not GPIO.input(LS1port) and GPIO.input(LS2port):
relaissturen(Luik2port)
if notificatie:
blynk.notify(“Luik 2 is geopend.”)
else:
if not GPIO.input(LS2port) and GPIO.input(LS3port):
relaissturen(Luik3port)
if notificatie:
blynk.notify(“Luik 3 is geopend.”)
else:
if not GPIO.input(LS3port) and GPIO.input(LS4port):
relaissturen(Luik4port)
if notificatie:
blynk.notify(“Luik 4 is geopend.”)
else:
if not GPIO.input(LS4port) and GPIO.input(LS5port):
relaissturen(Luik5port)
if notificatie:
blynk.notify(“Luik 5 is geopend. Voederautomaat bijvullen aub.”)
else:
if not GPIO.input(LS5port):
if notificatie:
blynk.notify(“Alle luiken zijn open. Gelieve de voederautomaat bij te vullen.”)
time.sleep(0.5)
verwerktLSstatus()
def verwerktLSstatus():
print(“start verwerktLSstatus”)
for poort in LSlist:
if GPIO.input(poort):
blynk.virtual_write(poort, 0)
#print(poort,’ uit’)
else:
blynk.virtual_write(poort, 255)
#print(poort,’ aan’)
def voederuur_controleren_en_bedienen(): #programma blok om te voorkomen dat het meerdere keren in een minuut voederd.
year, month, day, hour, minute = map(int, time.strftime("%Y %m %d %H %M").split())
if hour == Uur1 and minute == Min1 or hour == Uur2 and minute == Min2 or hour == Uur3 and minute == Min3 or hour == Uur4 and minute == Min4 or hour == Uur5 and minute == Min5:
print(time.asctime( time.localtime(time.time())),“Juiste uur: voederbeurt wordt gegeven na 59sec”)
wachten(59)
wachten(10)
blynk.run()
wachten(2)
wachten(2)
if returnV5==9:
else:
def Synchroniseer_uren():
print(time.asctime( time.localtime(time.time())),“Begin: uren, notificatie, TenH synchroniseren”)
meet_TenH()
blynk.run()
blynk.read_response(timeout=BlynkReadTimeOut)
blynk.virtual_sync(31)
blynk.virtual_sync(32)
blynk.virtual_sync(33)
blynk.virtual_sync(34)
blynk.virtual_sync(35)
print(time.asctime( time.localtime(time.time())),“Einde: uren, notificatie, TenH synchroniseren”)
schedule.every(30).seconds.do(Synchroniseer_uren)
schedule.every(6).seconds.do(verwerktLSstatus)
try:
while True:
    blynk.run()
    blynk.notify(str(time.asctime( time.localtime(time.time())))+": Hayfeeder is opgestart.")
    verwerktLSstatus()
    while True:
        blynk.run()
        schedule.run_pending()
        wachten(10)
except KeyboardInterrupt:
GPIO.cleanup()
Can anyone help me?
ps I am from Belgium some things are written in Dutch.
Arno
@ArnoVanDeynze please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
