Blynk + remote control need help
i am getting error at library irremote
#include IRremote.h
IRsend irsend;
unsigned int power[23] = {850,900, 1750,900, 850,900, 850,900, 850,900, 850,900, 850,900, 850,900, 850,1750, 950,800, 1750,900, 900};
char auth[] = “xxx”
char ssid[] = “xx”;
char pass[] = “xxxx1”;
BLYNK_WRITE(V1)
//int pinValue = param.asInt();
int khz = 38;
irsend.sendRaw(power, sizeof(irSignal) sizeof(irSignal[0]), khz);
Serial.print(power);
i AM GETTING THIS ERROR
sketch_mar10b:4: error: #include expects “FILENAME” or
#include IRremote.h
exit status 1
Please post your code with proper formatting…
#include ESP8266WiFi.h
#include BlynkSimpleEsp8266.h
#include IRremoteESP8266.h
IRsend irsend(0);
char auth[] = “xx”;
char ssid[] = “xx”;
char pass[] = “xxx”;
irsend.begin();
BLYNK_WRITE(V1) //Button Widget is writing to pin V1
int pinData = param.asInt();
Serial.print(pinData);
irsend.sendNEC(0xC, 36);
delay(20);
irsend.sendNEC(0xC, 12);
not good, @scientist1995, please use this:
```cpp
PUT YOUR CODE HERE
thanks!
