Blynk Raspberry Pi connection issue
I am able to connect my raspberry pi with my Android phone. But after some seconds I geht the notification “Your Raspberry Pi 2 is not in network”. After this, my led stops responding.
Can you please help?
Thank you
Let me check it… maybe you could take a look at my Node.js library for Blynk… it should be frendlier :wink:
Wäre can I find you library? :smile:
And supports your library the Raspberry Pi 2 B ?:slight_smile:
same problem here it tells me on the app that my Raspberry pi has been disconnected from the server
Ok, I can confirm the bug… I will fix it soon.
Regarding the Node.js implementation, here it is: https://github.com/vshymanskyy/blynk-library-js
Edit: Should be fixed in master branch.
did you get it to work??
