hi,
the project involves switching a led ON from the blynk app. the setup is:
-arduino uno and esp8266
-the blynk app is running on android 7.0.
-using blynk server and blynk library version v0.5.0
after getting the ready and ping status in arduino ide serial monitor, the project shows connected and disconnected in roughly 10 sec intervals. i am not understanding what i am doing wrong. please help
code:
#include <ESP8266_Lib.h>
char auth[] = "b136f026d8e54fa5b61e1ea45bc29eb1";
char ssid[] = "j5 net";
char pass[] = "shittyshit";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
void myTimerEvent()
// Set ESP8266 baud rate
Possible network issuesā¦ and too high a rate for a ESP/Arduino linkā¦ 9600 BAUD is recommended. And remember, you also have to change the ESP BAUD rate via AT commands as well as the sketch command.
For software serial - Yes (from my experience up to 33kbps), But for hardware UART Iām using 115kbps on Atmega32 and ESP-01 with 1.5.4 SDK without major issue. The only thing to handle is connection checking and hardware reset/reinit after it is lost (happens sometime - not very often). What is interesting, I tried newer version of SDK (2.0.0) and failed. It worksā¦ or notā¦ Without any noticeable reasonā¦
Correctā¦ I was too lazy to dig into code. Then it is a waay too fast for small Atmega on basic Arduino boardā¦ As noted - up to 33kbps it is working for me with SoftwareSerial
Then, there is other question: Why use software serial emulation in āproductionā (final) version of firmware at all?? Iām disabling all debug output, and using UART (or it is USART on ATMEGAās?) for ESP comm. The other option: Use DEBUG on software serial, and disable it after debugging?? Never tried this one thoughā¦
Because many Arduinos only have the one hardware UART, and swapping between ESP and programing is a painā¦ and you canāt reprogram an āArduino with shieldā via OTA, that I am aware ofā¦ but really all beyond the point of this topic
Makes no difference to this OPs issue, as the OP is using the programming port for the debug and the software port for the connection
That is all true, but I mean the āfinalā setup, where debug is not needed, as well as frequent flashing. Then ONE, and only one serial port seems to be fairly enough! Naturally a setup composited from ESP as a āshieldā and Arduino as a controller is much more inconvenient than just using ESP standalone and it should be noted whenever possible. But Iām not helping @ramchaitanya95 much with this discussion, soā¦
