I was wondering if someone knew what was the ports that the blynk client uses in the particle dev kits.
is it 8442 and is based on plain TCP/IP sockets?
meaning no security at all?
thank you!
Gustavo.
thank you!
Gustavo.
Hello. Correct. Blynk server supports also 8441 port that is for hardware that supports SSL/TLS and particle is not this hardware :).
@gusgonnet if security is important for you it is recommended to install Local Blynk Server. So hardware <-> server communication will be within local network with no security problems.
What is the hardware that supports SSL/TLS? I imagine one is the raspberry pi, the others are which ones?
thanks
@gusgonnet: There are many:
Also, there are some boards that should support direct SSL in theory (we didn’t try it with Blynk):
Hope that answers your question!
this answers my question, thank you.
another one: what work would be required to make Particle Photons or Electrons to be part of this list?
Is there a technical reason? maybe the hardware they use doesn’t support SSL/TLS?
or it could be a matter of time and work? maybe porting the BlynkBoard or the ESP8266 code to particle libs?
thanks a lot
Gustavo.
No, we can’t do that.
It’s current Particle platform limitation - they may decide to implement it at some point of time…
BUT - there are other options to build security. Gateway, local server, etc…
