I installed Blynk on a Rasperry Pi 4,
I have access to the control panel on my PC with the firefox page:
https://192.168.1.93:9443/admin#
admin@blynk.cc
admin
But on the iPhone Blynk app on the same wifi network:
login:
admin@blynk.cc
admin
with custom server:
192.168.1.93 9443
he said to me: Can’t connect to host
I put: server.properties in the same folder as the java
#hardware mqtt port
hardware.mqtt.port=8440
#http, plain web sockets and plain hardware port
http.port=8080
#if this property is true csv download url will use port 80 and will ignore http.port
force.port.80.for.csv=false
#if this property is true redirect_command will use 80 port and will ignore http.port
force.port.80.for.redirect=true
#secured https, web sockets and app port
https.port=9443
#address to bind to. by default bounded to all interfaces
listen.address=
#by default server uses embedded in jar cert to simplify local server installation.
#WARNNING DO NOT USE THIS CERTIFICATES ON PRODUCTION OR IN WHERE ENVIRNOMENTS REAL SECURITY REQUIRED.
This file has been truncated. show original
An idea ?
Thx
What happens if you put the custom server settings into the app then choose “create account”?
Pete/
the Edit configuration “server.properties” on page web :
initial.energy=100000
allow.reading.widget.without.active.app=false
user.message.quota.limit=100
logs.folder=./logs
user.dashboard.max.limit=100
lcd.strings.pool.size=6
server.ssl.key=
webhooks.response.size.limit=96
table.rows.pool.size=100
terminal.strings.pool.size=25
admin.email=admin@blynk.cc
admin.rootPath=/admin
user.widget.max.size.limit=20
listen.address=
blocking.processor.thread.pool.limit=6
stats.print.worker.period=60000
enable.db=false
enable.raw.db.data.store=false
restore.host=blynk-cloud.com
csv.export.data.points.max=43200
restore=false
user.profile.max.size=256
allow.store.ip=true
allowed.administrator.ips=0.0.0.0/0,::/0
net.interface=eth
webhooks.frequency.user.quota.limit=1000
http.port=8080
web.request.max.size=524288
user.devices.limit=50
async.logger.ring.buffer.size=2048
user.tags.limit=100
server.ssl.key.pass=
admin.pass=
hard.socket.idle.timeout=10
product.name=Blynk
data.folder=/home/pi/Blynk
map.strings.pool.size=25
profile.save.worker.period=60000
https.port=9443
log.level=info
server.ssl.cert=
notifications.queue.limit=2000
notifications.frequency.user.quota.limit=5
Can you ping the server from your phone?
Hi thx for the answer ;
i can ping it but the 9443 dosen’t it
I find in setting of the iphone
