Blynk notify
hi, i need help when i whant to uplod this sketch i resive error
this is my code:
#include <Ethernet.h>
char auth[] = "cce8f11**********07fae39";
IPAddress server_ip (10, 0, 0, 10);
// Mac address should be different for each device in your LAN
byte arduino_mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
IPAddress arduino_ip ( 192,   168,   1,  20);
IPAddress dns_ip     (  192,   168,   1,   1);
IPAddress gateway_ip ( 192,   168,   1,   1);
IPAddress subnet_mask(255, 255, 255,   0);
  Blynk.begin(auth);
    // Wait until connected
  // Notify immediately on startup
  Blynk.notify("Device started");
  // Setup a function to be called every minute
  timer.setInterval(60000L, notifyUptime);
  // Setup notification button on pin 2
  pinMode(2, INPUT_PULLUP);
  // Attach pin 2 interrupt to our handler
  attachInterrupt(digitalPinToInterrupt(2), notifyOnButtonPress, CHANGE);
void notifyUptime()
  long uptime = millis() / 60000L;
  // Actually send the message.
  // Note:
  //   We allow 1 notification per minute for now.
  Blynk.notify(String("Running for ") + uptime + " minutes.");
void notifyOnButtonPress()
  // Invert state, since button is "Active LOW"
  int isButtonPressed = !digitalRead(2);
  if (isButtonPressed) {
    Serial.println("Button is pressed.");
    Blynk.notify("Yaaay... button is pressed!");
my errore is:
Looks like you’re using old library, maybe from codebender?
Please use latest version
@vshymanskyy
We should add latest library to codebender as well
