Hardware Adruino nano 33 iot, using wifi
blynk 1.0.0.0 beta 3 library
android app version 2.27.28
so I can connect and get notification when device disconnects and reconnects. but I cannot in my code notification. I assume the compile error only thing holding me back. My virtualwrite works as it should so I know everything else is good. harware im simply jumping pin 3 and 5 to get output/input to later put in relay.
compile error i get is this…
C:\Users\DP\Desktop\nano 33\blynk\simple-notify\simple-notify.ino: In function ‘void checkPin()’:
C:\Users\DP\Desktop\nano 33\blynk\simple-notify\simple-notify.ino:52:26: warning: ‘void BlynkApi::notify(const T&) [with T = char [5]; Proto = BlynkProtocol<BlynkArduinoClientGenarduino::Client >]’ is deprecated [-Wdeprecated-declarations]
Blynk.notify(“here”);
In file included from C:\Users\DP\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14:0,
from C:\Users\DP\Documents\Arduino\libraries\Blynk\src/Adapters/BlynkWiFiCommon.h:24,
from C:\Users\DP\Documents\Arduino\libraries\Blynk\src/BlynkSimpleWiFiNINA.h:22,
from C:\Users\DP\Desktop\nano 33\blynk\simple-notify\simple-notify.ino:5:
C:\Users\DP\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:178:10: note: declared here
void notify(const T& msg) {
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
char auth[] = "XXXXXXXXXX";
char ssid[] = "NETGEARXXXXX";
char pass[] = "passwordXXXXX";
pinMode(3, OUTPUT); // OUTPUT FOR SWITCH
pinMode(5, INPUT); // INPUT FOW SWITCH
digitalWrite(3, HIGH); // sets the digital pin 3 on
int prevState = -1;
int currState = -1;
long lastChangeTime = 0;
void checkPin()
int state = digitalRead(5);
// Debounce mechanism
long t = millis();
if (state != prevState) {
lastChangeTime = t;
if (t - lastChangeTime > 1000) {
if (state != currState) {
currState = state;
Blynk.virtualWrite(V1, state);
Blynk.notify("here");
Serial.println("pressed");
prevState = state;
checkPin();
