I have been working on a project for motion controlled LED lights with other things integrated (different modes and such). I have tested the majority of my code using Serial.println() to check updated values like brightness, motion sensors enabled or disabled, etc and it works in theory.
I have a IR motion sensor attached to Pin 7 and it inputs data correctly for the code to read, but the LED strip does not light up.
ESP is connected to pins 2 and 3 correctly (connects to my phone)
LED strip is connected to an external power source and properly grounded (worked with other NeoPixel projects I have)
Can someone help me solve this issue and get the LED strip to show?
#include <ESP8266_Lib.h>
#include <Adafruit_NeoPixel.h>
//Initial Blynk Setup
char auth[] = "BwcgSJY_PNZSFHjnddyvZLX2zIoCkpoS";
char ssid[] = "Wireless 2.4Ghz";
char pass[] = "dozerhank";
ESP8266 wifi(&EspSerial);
#define ESP8266_BAUD 9600
//IR Motion Sensors
int sensorPin = 7;
int indicator = 13;
//Color Values
int Red = 0;
int Green = 0;
int Blue = 255;
//Mode Values
int Mode = -1; //0 is solid already ran, 1 is solid, 2 is rainbow, 3 is Fade
int ModeMotionSensor = 0;
//Other LED Values
int Brightness = 150;
int ModeSpeed = 500;
int ledCount = 417;
int Duration = 1000; // every 100 = 1 sec
int ledTimer = 0;
int ledPin = 5;
//Define Strip object
Adafruit_NeoPixel strip(ledCount, ledPin, NEO_GRB + NEO_KHZ800);
strip.begin();
strip.show();
strip.setBrightness(Brightness);
pinMode(sensorPin, INPUT);
pinMode(indicator, OUTPUT);
FillRoom();
//Decide which mode to run on LED lights
if (Mode == 1) {
Solid();
} else if (Mode == 2) {
Rainbow();
} else if (Mode == 3) {
//Fade();
//When motion sensor is on
if (ModeMotionSensor == 1) {
MotionSensor();
ledTimer--;
} else if (ModeMotionSensor == 0) {
ledTimer = Duration;
if (ledTimer == 0) {
ledClear();
//Controlling Mode Value and reassings mode in function
BLYNK_WRITE(V0) {
if (param[0].asInt() == 1) {
if (Mode != 0) {
Mode = 1;
} else if (param[0].asInt() == 2) {
Mode = 2;
} else if (param[0].asInt() == 3) {
Mode = 3;
//Controls the RGB Color and reassigns RGB values in function
BLYNK_WRITE(V1) {
Red = param[0].asInt();
Green = param[1].asInt();
Blue = param[2].asInt();
//Controlls the Mode speed for effects and assigns value
BLYNK_WRITE(V2) {
ModeSpeed = param[0].asInt();
//Check if Motion Sensor is on or off and reassigns value
BLYNK_WRITE(V3) {
ModeMotionSensor = param[0].asInt();
//Adjust Brightness and reassigns value
BLYNK_WRITE(V4) {
Brightness = param[0].asInt();
void FillRoom() {
strip.clear();
strip.show();
for (int i = 0; i < ledCount; i++) {
strip.setPixelColor(i, strip.Color(Red, Green, Blue));
strip.show();
//Solid Mode Function
void Solid() {
return;
strip.fill(strip.Color(Red, Green, Blue));
strip.show();
Mode = 0;
//Rainbow Mode Function
void Rainbow() {
return;
for (long firstPixelHue = 0; firstPixelHue < 5*65536; firstPixelHue += 256) {
for(int i = 0; i < strip.numPixels(); i++) {
int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
strip.show();
delay(ModeSpeed / 20);
//Detect when someone is present
void MotionSensor() {
if (digitalRead(sensorPin) > 0) {
//When no motion is detected, turn off
void ledClear() {
strip.setPixelColor(i, strip.Color(0, 0, 0));
