HI Team ,Gm ,strugguling iwth below issue in code or somwhere
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
#define BLYNK_TEMPLATE_ID "TMPLKEnUt9gN"
#define BLYNK_DEVICE_NAME "binder6253"
#define BLYNK_AUTH_TOKEN "wbKURuuWJEwxvUtvUdz-V6QunplJ6dRk"
char auth[] = BLYNK_AUTH_TOKEN ;
char ssid[] = "My airtel 1";
char pass[] = "Tcs@6253";
// Blynk.begin(auth, ssid, pass);
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
I am getting this in serial monitor but device say offline always after connecting to nodemcu to 12v supply ,do we can power it by connecting to micro usb port instead of pin power ,i tried multiple times and has blynk version 1.01 . and device blynk iot app
[349844] Connecting to blynk.cloud:80
[349958] Ready (ping: 58ms).
[364182] Connecting to blynk.cloud:80
[364318] Ready (ping: 68ms).
[378516] Connecting to blynk.cloud:80
[378618] Ready (ping: 52ms).
Despite @John93 giving you triple backticks (```) you have not used them and properly formatted your code. I have done that for you this time. Next tim the code will be removed by the moderator.
I’d suggest that you change this to 74880 and re-upload your sketch.
Then, press the reset button on your board and post the serial output that follows.
Place triple backticks at the beginning and end of this serial output, on a separate line, when you post it to the forum. This is so that it displays correctly.
You are using a very old version of the Blynk library,m which doesn’t support Blynk IoT.
You should install version 1.1.0 of the Blynk C++ library, and ensure that you don’t have any old versions of the library installed.
Please don’t do this.
I have no idea what this comment means.
The Serial.begin() command in your original post used a baud rate of 9600. The native baud rate of most ESP8266 boards is 74880. By changing the Serial.begin command to use 74880 and using the same baud rate in your serial monitor means they you should see the boot messages from your board, along with the debug output from your sketch in the serial monitor. This can be useful in some situations.
Thanks for response ,the code seems working in serial monitor as it give print out value like led1 on but it didnot turn off the pin on board like D5,D6,D7 D8 but it do little dim the led on press button by app as the signal seems still high ,using 12 v supply for 12v relay and same supply to nodemcu, i attached load also but it did not turn off and always on .
