Blynk need always to be restarted
I recently installed blynk on an AWS ec2 Instance.
I know that it is perhaps something that people do not use to do , as i saw very few experienes of that on the web …But, I thought it could be interesting !
It works fine , But, After a certain amount of time (perhaps 24 hours), i need to restart the blynk server , due to lost of connection.
I tried with differents versions of bBlynk server and differents versions of java jdk => Same problem
I tried with differents versions of Server ( redhat, fedora , aws …) => Same problem
Are there anyything special to configure to avoid to always have to restart the server ?
Any help would be really appreciate .
David
I think you need to fix the problem on the hardware side. Your hardware client should be able to reconnect after the connection is lost. I don’t think server has something to do with that.
