Hello friends.
After some research, I made everything work as I wanted it to.
Now I would like to improve.
I’m trying to add MQTT connection in the project.
NodeMCU + 3 Relays + 3 lamps + 3 physical buttons (push button)
Here is the code that is working:
#include <ESP8266WiFi.h> //INCLUSÃO DE BIBLIOTECA
#include <BlynkSimpleEsp8266.h> //INCLUSÃO DE BIBLIOTECA
char auth[] = "XXXXXXXXX"; //AUTH TOKEN (FORNECIDO PELO PROJETO NO BLYNK E POR E-MAIL)
char ssid[] = "XXXXXXXXXXX"; //VARIÁVEL QUE ARMAZENA O NOME DA REDE SEM FIO EM QUE VAI CONECTAR
char pass[] = "XXXXXXXXXXX"; //VARIÁVEL QUE ARMAZENA A SENHA DA REDE SEM FIO EM QUE VAI CONECTAR
const int relePin1 = D2; //PINO EM QUE O RELÉ ESTÁ CONECTADO
const int relePin2 = D3; //PINO EM QUE O RELÉ ESTÁ CONECTADO
const int relePin3 = D4; //PINO EM QUE O RELÉ ESTÁ CONECTADO
const int pulsadorPin1 = D5; //PINO EM QUE O PULSADOR ESTÁ CONECTADO
const int pulsadorPin2 = D6; //PINO EM QUE O PULSADOR ESTÁ CONECTADO
const int pulsadorPin3 = D7; //PINO EM QUE O PULSADOR ESTÁ CONECTADO
BlynkTimer timer; //OBJETO DO TIPO BlynkTimer
void checkPhysicalButton(); //FUNÇÃO checkPhysicalButton
int releState1 = HIGH; //ESTADO INICIAL DO RELÉ
int releState2 = HIGH; //ESTADO INICIAL DO RELÉ
int releState3 = HIGH; //ESTADO INICIAL DO RELÉ
int pulsadorState1 = HIGH; //ESTADO INICIAL DO PULSADOR
int pulsadorState2 = HIGH; //ESTADO INICIAL DO PULSADOR
int pulsadorState3 = HIGH; //ESTADO INICIAL DO PULSADOR
void setup(){
Blynk.begin(auth, ssid, pass); //INICIALIZA A COMUNICAÇÃO BLYNK INFORMANDO OS PARÂMETROS
pinMode(relePin1, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(relePin2, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(relePin3, OUTPUT); //DECLARA O PINO COMO SAÍDA
pinMode(pulsadorPin1, INPUT_PULLUP); //DECLARA O PINO COMO ENTRADA E ATIVA O RESISTOR INTERNO DE PULL UP DO ESP
pinMode(pulsadorPin2, INPUT_PULLUP); //DECLARA O PINO COMO ENTRADA E ATIVA O RESISTOR INTERNO DE PULL UP DO ESP
pinMode(pulsadorPin3, INPUT_PULLUP); //DECLARA O PINO COMO ENTRADA E ATIVA O RESISTOR INTERNO DE PULL UP DO ESP
digitalWrite(relePin1, releState1); //RELÉ RECEBE O ESTADO INICIAL
digitalWrite(relePin2, releState2); //RELÉ RECEBE O ESTADO INICIAL
digitalWrite(relePin3, releState3); //RELÉ RECEBE O ESTADO INICIAL
timer.setInterval(100L, checkPhysicalButton); //DEFINE O INTERVALO DE 100 MILISSEGUNDOS(100L = 100 MILISSEGUNDOS) PARA EXECUÇÃO DA FUNÇÃO checkPhysicalButton
BLYNK_CONNECTED() { //FUNÇÃO QUE VERIFICA A CONEXÃO COM O SERVIDOR
Blynk.syncVirtual(V2); //REQUISITA O ÚLTIMO ESTADO DO PINO VIRTUAL 2
Blynk.syncVirtual(V3); //REQUISITA O ÚLTIMO ESTADO DO PINO VIRTUAL 3
Blynk.syncVirtual(V4); //REQUISITA O ÚLTIMO ESTADO DO PINO VIRTUAL 4
BLYNK_WRITE(V2) { //FUNÇÃO QUE MUDA O ESTADO DO RELÉ QUANDO O BOTÃO NO APP É PRESISONADO
releState1 = param.asInt(); //VARIÁVEL RESPONSÁVEL POR RECEBER E ARMAZENAR O DADO VINDO DO APP
digitalWrite(relePin1, releState1); //ALTERNA O ESTADO ATUAL DO RELÉ
BLYNK_WRITE(V3) { //FUNÇÃO QUE MUDA O ESTADO DO RELÉ QUANDO O BOTÃO NO APP É PRESISONADO
releState2 = param.asInt(); //VARIÁVEL RESPONSÁVEL POR RECEBER E ARMAZENAR O DADO VINDO DO APP
digitalWrite(relePin2, releState2); //ALTERNA O ESTADO ATUAL DO RELÉ
BLYNK_WRITE(V4) { //FUNÇÃO QUE MUDA O ESTADO DO RELÉ QUANDO O BOTÃO NO APP É PRESISONADO
releState3 = param.asInt(); //VARIÁVEL RESPONSÁVEL POR RECEBER E ARMAZENAR O DADO VINDO DO APP
digitalWrite(relePin3, releState3); //ALTERNA O ESTADO ATUAL DO RELÉ
void checkPhysicalButton(){ //FUNÇÃO QUE VERIFICA O PRESSIONAMENTO DO PULSADOR
if (digitalRead(pulsadorPin1) == LOW) { //SE LEITURA DO PULSADOR FOR IGUAL A LOW, FAZ
if (pulsadorState1 != LOW) { //SE O ESTADO DO PULSADOR FOR DIFERENTE DE LOW (OU SEJA, HIGH), FAZ
releState1 = !releState1; //ESTADO DO RELÉ, RECEBE O ESTADO ATUAL INVERTIDO
Blynk.virtualWrite(V2, releState1); //ATUALIZA NO WIDGET O ESTADO ATUAL (INDEPENDENTE SE FOI ACIONADO VIA APP OU PULSADOR)
pulsadorState1 = LOW; //ESTADO DO PULSADOR RECEBE LOW
}else{ //SENÃO, FAZ
pulsadorState1 = HIGH; //ESTADO DO PULSADOR RECEBE HIGH
if (digitalRead(pulsadorPin2) == LOW) { //SE LEITURA DO PULSADOR FOR IGUAL A LOW, FAZ
if (pulsadorState2 != LOW) { //SE O ESTADO DO PULSADOR FOR DIFERENTE DE LOW (OU SEJA, HIGH), FAZ
releState2 = !releState2; //ESTADO DO RELÉ, RECEBE O ESTADO ATUAL INVERTIDO
Blynk.virtualWrite(V3, releState2); //ATUALIZA NO WIDGET O ESTADO ATUAL (INDEPENDENTE SE FOI ACIONADO VIA APP OU PULSADOR)
pulsadorState2 = LOW; //ESTADO DO PULSADOR RECEBE LOW
}else{ //SENÃO, FAZ
pulsadorState2 = HIGH; //ESTADO DO PULSADOR RECEBE HIGH
if (digitalRead(pulsadorPin3) == LOW) { //SE LEITURA DO PULSADOR FOR IGUAL A LOW, FAZ
if (pulsadorState3 != LOW) { //SE O ESTADO DO PULSADOR FOR DIFERENTE DE LOW (OU SEJA, HIGH), FAZ
releState3 = !releState3; //ESTADO DO RELÉ, RECEBE O ESTADO ATUAL INVERTIDO
Blynk.virtualWrite(V4, releState3); //ATUALIZA NO WIDGET O ESTADO ATUAL (INDEPENDENTE SE FOI ACIONADO VIA APP OU PULSADOR)
pulsadorState3 = LOW; //ESTADO DO PULSADOR RECEBE LOW
}else{ //SENÃO, FAZ
pulsadorState3 = HIGH; //ESTADO DO PULSADOR RECEBE HIGH
void loop(){
Blynk.run(); //INICIALIZA O BLYNK
timer.run(); //INICIALIZA O TIMER
And the frustrated attempt to introduce MQTT (Initially just publish):
#include <PubSubClient.h>
WiFiClient espClient;
PubSubClient client(espClient);
char auth[] = "XXXXXXXXXXX"; //AUTH TOKEN (FORNECIDO PELO PROJETO NO BLYNK E POR E-MAIL)
char ssid[] = "XXXXXXXXXXXXX"; //VARIÁVEL QUE ARMAZENA O NOME DA REDE SEM FIO EM QUE VAI CONECTAR
const char* mqtt_server = "192.168.0.127";
const char* mqtt_username = "mqtt";
const char* mqtt_password = "mqttpw";
const char* state_topicv2 = "casa/escritorio/luz/state";
const char* state_topicv3 = "casa/varanda/luz/state";
const char* state_topicv4 = "casa/quintal/luz/state";
const char* set_topicv2 = "casa/escritorio/luz/set";
const char* set_topicv3 = "casa/varanda/luz/set";
const char* set_topicv4 = "casa/quintal/luz/set";
int ReCnctFlag; // Reconnection Flag
int ReCnctCount = 0; // Reconnection counter
// conectando ao servidor por MQTT
void connect_client() {
// Espera ate estar conectado ao servidor
while (!client.connected()) {
// Cria cliente ID randômico
String clientId = "ESP8266Client-";
clientId += String(random(0xffff), HEX);
// Tentativa de conexão
if (client.connected(clientId.c_str())) {
// Espera 5 segundo e tenta novamente
delay(5000);
void setup(){
client.setServer(mqtt_server, 1883); //Configura servidor
// Verifica se está conectado ao servidor MQTT. Se nao, tenta conectar-se.
if (!client.connected()) {
connect_client();
client.publish(state_topicv2,releState1); //ALTERA O ESTADO ATUAL NO MQTT
client.publish(state_topicv3,releState2); //ALTERA O ESTADO ATUAL NO MQTT
client.publish(state_topicv4,releState3); //ALTERA O ESTADO ATUAL NO MQTT
}else{ //SENÃO, FAZ
}else{ //SENÃO, FAZ
}else{ //SENÃO, FAZ
void loop(){
if (Blynk.connected()) { // If connected run as normal
} else if (ReCnctFlag == 0) { // If NOT connected and not already trying to reconnect, set timer to try to reconnect in 30 seconds
ReCnctFlag = 1; // Set reconnection Flag
timer.setTimeout(30000L, []() { // Lambda Reconnection Timer Function
ReCnctFlag = 0; // Reset reconnection Flag
ReCnctCount++; // Increment reconnection Counter
Blynk.connect(); // Try to reconnect to the server
}); // END Timer Function
Can anybody help me?
