Hello Fellow Blynkers,
I get the below error each time I try to compile the blynk code. I have tried compiling the Blynk 1.0.1 and also tried Blynk Library master and every time, I get the below error. I have installed all necessary packages including millis.timer. Please help.
Board Info
Arduino RP2040
Using the MKR1010 sketch.
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp:151:12: error: 'Timer' does not name a type; did you mean 'time'?
static Timer blynk_millis_timer;
time
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp:152:12: error: 'Ticker' does not name a type; did you mean 'Socket'?
static Ticker blynk_waker;
Socket
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp: In function 'void BlynkSystemInit()':
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp:162:9: error: 'blynk_waker' was not declared in this scope
blynk_waker.attach(&blynk_wake, 2.0);
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp:162:9: note: suggested alternative: 'blynk_wake'
blynk_wake
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp:163:9: error: 'blynk_millis_timer' was not declared in this scope
blynk_millis_timer.start();
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp:163:9: note: suggested alternative: 'millis_time_t'
millis_time_t
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp: In function 'void BlynkDelay(millis_time_t)':
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp:168:9: error: 'wait_ms' was not declared in this scope
wait_ms(ms);
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp:168:9: note: suggested alternative: 'wait_ns'
wait_ms(ms);
wait_ns
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp: In function 'millis_time_t BlynkMillis()':
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp:173:16: error: 'blynk_millis_timer' was not declared in this scope
return blynk_millis_timer.read_ms();
C:\Users\dipot\Documents\Arduino\libraries\blynk-library-master\src\utility\BlynkDebug.cpp:173:16: note: suggested alternative: 'millis_time_t'
millis_time_t
exit status 1
Error compiling for board Arduino Nano RP2040 Connect.
