hi all, how i can set blynk menu? how i can set the if? Can you send me some sketch?
thank you very much
Smone.
hi dmitriy, i had read this sketch but, i don’t know where put if
What is this “if” you keep mentioning?? Menu selection uses switch case
Perhaps you can explain your question better?
Thank You.
When i select an item, i want that some led is on but, i don’t know how to do ( sorry for my english)
Read the Documents for the Menu Widget
http://docs.blynk.cc/#widgets-interface-menu
It uses the Switch Case command I mentioned (check that green link out as well).
Then add commands to do stuff where required…
switch (param.asInt())
case 1: { // Item 1
//Run some command here
break;
case 2: { // Item 2
// Runs some other command here
break;
case 3: { // Item 3
// etc...
break;
I’ll try thank you!
