Blynk.logEvent causes a crash/freeze/non responsive
Have searched for this and cannot find any info on this particular error. Maybe I am not doing something right.
My sketch works great, however, when this command is inserted, the serial monitor and blynk IoT stops working. I see the seconds in Blynk count up for a couple seconds, then everything stops.
  if ( Percent / 1000 <= 25 && millis() > 60000 ) {
        Blynk.logEvent("low_water","Please add water to Piney!")
        Serial.println("add water to tree");
The if condition is not even met, yet it stops the entire thing.
But if I just comment out that one line as so…
  //      Blynk.logEvent("low_water","Please add water to Piney!");
then the rest of the program and I see the rest of the data on Blynk.
I do have the event setup in Blynk.
EDIT: any instance of Blynk.logEvent(“eventname”) causes entire program to not run on Blynk. I have tried it many ways.
FYI… full code here: (please excuse sloppy code, I am beginner :slight_smile: )
  WARNING!
    It's very tricky to get it working. Please read this article:
    http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
  You’ll need:
   - Blynk IoT app (download from App Store or Google Play)
   - Arduino Uno board
  started. Think of them as LEGO bricks  and combine them as you wish.
  example.
#define BLYNK_TEMPLATE_ID           "redacted"
#define BLYNK_DEVICE_NAME           "Quickstart Template"
#define BLYNK_AUTH_TOKEN            "redacted"
#include <ESP8266_Lib.h>
char ssid[] = "redacted";
char pass[] = "redacted";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
const int OUT_PIN = A2;
const int IN_PIN = A4;
//Capacitance between IN_PIN and Ground
//Stray capacitance value will vary from board to board.
//Calibrate this value using known capacitor.
const float IN_STRAY_CAP_TO_GND = 24.48;
const float IN_CAP_TO_GND  = IN_STRAY_CAP_TO_GND;
//Pullup resistance will vary depending on board.
//Calibrate this with known capacitor.
const float R_PULLUP = 34.8;  //in k ohms
const int MAX_ADC_VALUE = 1023;
float capacitance;
#include <Smoothed.h>   // Include the library
Smoothed <float> mySensor;
Smoothed <float> mySensor2;
int full = 1100;
int empty = 400;
int freq = 100;
int momentTime = 1000;
void myTimerEvent()
void waterLevel()
    float smoothedSensorValueAvg = mySensor.get();
    //Capacitor under test between OUT_PIN and IN_PIN
    //Rising high edge on OUT_PIN
    pinMode(IN_PIN, INPUT);
    digitalWrite(OUT_PIN, HIGH);
    int val = analogRead(IN_PIN);
    digitalWrite(OUT_PIN, LOW);
      //Big capacitor - so use RC charging method
      //discharge the capacitor (from low capacitance test)
      pinMode(IN_PIN, OUTPUT);
      while (millis() % (1000) != 0) //Default 1000
      //Start charging the capacitor with the internal pullup
      pinMode(OUT_PIN, INPUT_PULLUP);
      unsigned long u1 = micros();
      unsigned long t;
      int digVal;
      //Charge to a fairly arbitrary level mid way between 0 and 5V
      //Best not to use analogRead() here because it's not really quick enough
      do
        digVal = digitalRead(OUT_PIN);
        unsigned long u2 = micros();
        t = u2 > u1 ? u2 - u1 : u1 - u2;
      } while ((digVal < 1) && (t < 400000L));
      pinMode(OUT_PIN, INPUT);  //Stop charging
      //Now we can read the level the capacitor has charged up to
      val = analogRead(OUT_PIN);
      //Discharge capacitor for next measurement
      digitalWrite(IN_PIN, HIGH);
      int dischargeTime = (int)(t / 1000L) * 5;
      delay(dischargeTime);    //discharge slowly to start with
      pinMode(OUT_PIN, OUTPUT);  //discharge remainder quickly
      digitalWrite(IN_PIN, LOW);
      //Calculate and print result
      capacitance = -(float)t / R_PULLUP
                              / log(1.0 - (float)val / (float)MAX_ADC_VALUE);
      capacitance = capacitance*1000;
    // Read the value from the sensor
    float currentSensorValue = capacitance;
    // Add the new value to both sensor value stores
    mySensor.add(currentSensorValue);
    // Get the smoothed values
    //float smoothedSensorValueAvg = mySensor.get();
    // Output the smoothed values to the serial stream. Open the Arduino IDE Serial plotter to see the effects of the smoothing methods.
    float Percent = constrain(map(smoothedSensorValueAvg,empty,full,0,100000),0,100000);
  Blynk.virtualWrite(V6, Percent/1000);
  Blynk.virtualWrite(V7, smoothedSensorValueAvg);
  // Set ESP8266 baud rate
 Serial.println("baud rate set complete!");
  //Blynk.begin(auth, wifi, ssid, pass, "blynk.cloud", 80);
  //Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
 Serial.println("connected to Blynk complete!");
  timer.setInterval(2000L, waterLevel);
 Serial.println("timer interval set complete!");
 //Serial.println("initializing pinmodes 1...");
  //digitalWrite(OUT_PIN, LOW);  //This is the default state for outputs
//Serial.println("initializing pinmodes 2...");
  //digitalWrite(IN_PIN, LOW);
 //Serial.println("initializing smoothed...");
  mySensor.begin(SMOOTHED_AVERAGE, 25);  //Default 50
 //Serial.println("initializing sensor clear...");
  mySensor.clear();
 Serial.println("Setup loop complete!");
  // to avoid delay() function!
Hey there,
I’d recommend you to try a simple sketch to send the event just to make sure it’s working.
Some information about the Blynk library version you are using, how your Event is configured and what you see in your serial monitor from boot-up through to crash would be useful.
Library version installed:
Serial monitor when Blynk.logEvent is used (never connects to Blynk):
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v1.0.1 on Arduino Uno
[624] Connecting to FBI Surveillance Van 3
[3811] AT version:1.1.0.0(May 11 2016 18:09:56)
SDK version:1.5.4(baaeaebb)
compile time:May 20 2016 15:08:19
OK
[7108] +CIFSR:STAIP,"192.168.1.132"
+CIFSR:STAMAC,"e8:db:84:96:54:4d"
[7116] Connected to WiFi
[17482] Ready (ping: 39ms).
[48551] Ready (ping: 39ms).
[79346] Ready (ping: 40ms).
[110147] Ready (ping: 40ms).
[140952] Ready (ping: 39ms).
Serial monitor when Blynk.logEvent is removed from code:
    ___  __          __
OK
[4889] Failed to enable MUX
[8102] +CIFSR:STAIP,"192.168.1.132"
[8112] Connected to WiFi
[18476] Ready (ping: 38ms).
I have had success as @John93 suggested by putting it into a simple sketch. So I came back and put it into the myTimerEvent() function and it worked! However, I really need it in the waterLevel() function, and it will not work there, but other Blynk commands do. I will keep working on trying to figure this out. Thanks for the help. :slight_smile:
in my opinion it’s better to use an ultrasonic sensor to measure the water level, I’d use an HCSR-04 to measure the water level and turn it into a percentage.
I’d try simplifying your waterLevel() function, initially by taking out the smoothing code and find-out what it is about that function that causes the problem.
Also, you shouldn’t have pinMode statements in your functions like this, they belong in void setup.
If your problems persist then I’d try using different pins.
