Blynk Local Server : Email Question/Clarification
Hi. I noticed that when I do a request to export a graph from my ioS Blynk app it correctly sends an email to my nominated email account (I’m using a local Blynk Server); what I received in the email is a link:
http://blynk-cloud.com:8080/xxxxx@gmail.com_680961728_v2.csv.gz” — is this normal operation ?
i.e. I was expecting the actual CSV file to be sent as an attachment to my email address not a link that I then need to find on my local server.
@mars,
Try to remove reset-pass.http.host property from your server.properties file and restart server
My Local Server did the same time ago and this trick provided by Dmitriy worked fine.
thanks that seemed to do the trick, thanks.
I assume the very large number which is time is based on unix time i.e. seconds from 1970 ?
Yes, that’s correct.
Review info below:
http://docs.blynk.cc/#blynk-server-advanced-local-server-setup-raw-data-storage
Regards
