Blynk live again
Seems maintenance work is in progress… connection lost again​:sob::sob:
At what IP-address? Both cloud.blynk.cc and blynk-cloud.com resolve to 45.55.195.102 in my router and both don’t answer to a ping request. My ESP module continues to print “Connecting to cloud.blynk.cc:8442” to serial, but can’t seem to connect.
My ESP is working now. Restart router or something.
Can you ping the cloud server? What IP-address does it resolve to?
On http://www.downforeveryoneorjustme.com/ I also don’t get a positive indication.
Hello.
You should not use IP address. Please use blynk-cloud.com host instead.
You may try to restart your router/hardware it may help. Otherwise you have to wait until DNS records will be updated in your ISP.
Thanks for your reply. I know I should use blynk-cloud.com. I just mention the IP-address to check if my router resolves to the same server as the one that should work now. Should ping also work? Is the IP-address correct or should the url resolve to another server? (I also checked http://www.isup.me/blynk-cloud.com)
Yes. It should work.
Yes. It should.
It should be resolved to another IP. Look like your ISP didn’t update DNS records yet. It also could be a local issue. System/hardware/router restart may help.
That matches my findings. Probably my providers had the old IP in its nameserver cache. Will try again sometime later. Thanks for your help.
Hey guys… Might have missed the memo, but now that Blynk is bak online my history graphs are empty in my app? I had data for nearly a month.
History data will be restored later.
I am still unable to reconnect via the USB script. Is this the same issue?
@arduinewb are you able to ping servers with “ping blynk-cloud.com”?
Hmm… indeed my provider seems to have a slow DNS-update policy. Reboot of the router wasn’t sufficient. Had to change the DNS’es in the router to the google DNS’es to get the proper IP.
Albeit perhaps a bit flaky with an occasional outage notification, my board is now connected to the cloud. Hooray!
@Dmitriy I get the following:
@arduinewb yeap, DNS record not yet updated. Sorry we can’t do anything here. Maybe @maxint approach would help you.
I’m also not able to connect my arduino.
Disparando blynk-cloud.com [45.55.130.102] com 32 bytes de dados:
Resposta de 45.55.130.102: bytes=32 tempo=168ms TTL=51
Resposta de 45.55.130.102: bytes=32 tempo=1275ms TTL=51
Resposta de 45.55.130.102: bytes=32 tempo=333ms TTL=51
Resposta de 45.55.130.102: bytes=32 tempo=221ms TTL=51
Have you rebooted your router since the outage?
Yes. but still the same way
C:\Users\Windows>ping blynk-cloud.com
Resposta de 45.55.130.102: bytes=32 tempo=180ms TTL=51
Resposta de 45.55.130.102: bytes=32 tempo=179ms TTL=51
Resposta de 45.55.130.102: bytes=32 tempo=184ms TTL=51
Estatísticas do Ping para 45.55.130.102:
Pacotes: Enviados = 4, Recebidos = 4, Perdidos = 0 (0% de
perda),
Yes steady reply from 188.166.177.186 @ 62 ms
