Hi Guys
I am thinking of updating to v5 as it now supports the Arduino Uno Wifi which I have will I be able to use sketch builder with the Arduino Uno Wifi
Should I choose the Uno Board and esp8266 as the Wifi
Thanks oldvolt
First use Uno WiFi Serial1 library and install WiFi Link in your Uno WiFi Developer Edition. Then [Solved] Arduino.org Uno WiFi board with Firmware 1.0.0 and WiFiLink.h Librairies
Juraj
If you have time to respond to this reply may I please have some advice I have tried several times to upload the firmware and its not uploading I have attached 2 screen shots
uno wifi 3|690x387
I have also attached a list of the firmware files I am using
thanks oldvolt
sorry, I didn’t see your reply. You should use the Uno WiFi Dev Ed Serial1 library and Arduino esp8266 core to install WiFi Link
