Blynk LED Status of Button With 2 Inputs
I have a project at home to monitor 2 digital switches on Blynk dash board and on the Mobile app.
The sketch on Blynk Example builder is working ok.
Need code for 2 switches.
I have WeMos D1 R1 board
Searched on you tube and other resources but these codes are not compatible with Blynk libraries.
You can search the forum, there’s a lots of examples.
Why don’t you do as was suggested and…
The information you were prompted for when you created this project would be a good starting point…
  1. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
```cpp
It would also be extremely useful i9f you used the following terminology…
Physical Switch - a mechanical component attached to your board
Switch Widget - A widget on the mobile or web console dashboard
Datastream Type - The type of datastream you chose when you created the datastream (Digital, Analog, Virtual Pin, Enumerable etc)
