@PeteKnight esp32 past the first test, now for the longevity test, run for at least 24hrs. Really should be 80+hrs. Read a value from a sensor and display it using Blynk.
So far it does seem to be more solid than the board I was using.
A suggestion is to test the boards with a similar reference test. Publishing the versions used and the hardware.
