just bought the omega onion 2+ and I’m trying to connect it with blynk. I’m using putty terminal and installed the blynk library etc. on the omega2+. the code I’m using is below.
var BlynkLib = require('/usr/bin/blynk-library');
var blank = new BlynkLib.Blynk('TOKEN');
var Gpio = require('/usr/bin/onoff-node/onoff.js').Gpio;
var led = new Gpio(11,'out');
var num = 1;
var v1 = new blynk.Virtual.Pin(1);
var v5 = new blynk.VirtualPin(5);
v1.on('write', function(param) {
console.log('V1:', param);
v5.on('write', function(param) {
this.num ^=1;
led.writeSync(this.num);
multiple website have it listed as " getting started " so it should work. but everytime i try to run it says " blynk is not defined " and will not work. onion omega and blynk are not connecting. please help.
