hello,
previously i use blynk legacy and now its not working.i try to use blynk new app and that new time input widget very difficult to understand. previous app too easy to use .can anyone upload a sample code to power on one digital pin a selected time and turn off an hour.
The “Time Input” widget in IoT is the same as it was in Legacy.
The Legacy “Timer” widget has been replaced with Automations. Take a look at the documentation and you’ll see a great tutorial on how to implement Automations.
@EduardoSantino ive deleted your post from this topic.
Please don’t hijack other people’s topics in this way. You should start a new “need help…” topic of your own and provide ALL of the requested information along with a full explanation of your problem and all of the relevant information to make it understandable.
sto cercando un timer per far partire una pompa 12v, esempio tasto V1 on off per accenderla e un timer accanto per impostare dalle 12:00 on e ore 13:00 off. Con il vecchio blynk era un gioco da ragazzi ora è complicato.
