BLYNK
BLYNK.IO       📲 GETTING STARTED       đź“— DOCS       👉 SKETCH BUILDER
Blynk IoT 2.0 - TERMINAL
One doubt regarding terminal widget:
Is there a possibility to:
  1. Change font size?
  2. Change font type?
Why i’m answering that:
In legacy Blynk, terminal was composed with an regular font that shows equals spaces between characters… All informations showed on terminal were aligned. But now, with Blynk 2.0 terminal uses some kind of true type font and then text is not aligned…
I’ve changed this from a “Need help…” to an “Ideas” topic because having the option for a monospaced font rather than a proportional spaced font seems like a sensible idea, so that data can be formatted in columns.
Especially useful now we don’t have the Table widget.
@MarkPan is this one for you to discuss with the design team?
Not sure from the original post if this request applies to both flavours of the app and/or the web console widget, but they should obviously all behave the same way.
The font will be changed with a few more additional tweaks. It appears terminal is not that simple as it looks :).
