Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.Code should be formatted as example below.
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
char auth[] = "rQ1907mb6hd3jhk3fR9foeukSDNY2-1b";
char ssid[] = "DESKTOP-QSM11GA 7050";
char pass[] = "N32h,498";
Serial.print("TEMPRATURE = ");
Blynk.begin(auth, ssid, pass,80);
Serial.print("loop");
20:24:22.914 -> [19314] Connecting to 144.31.0.0
20:24:29.290 -> [25661] Connecting to 144.31.0.0
20:24:35.617 -> [32002] Connecting to 144.31.0.0
20:24:41.945 -> [38339] Connecting to 144.31.0.0
20:24:48.320 -> [44678] Connecting to 144.31.0.0
20:24:54.647 -> [51017] Connecting to 144.31.0.0
20:25:00.975 -> [57357] Connecting to 144.31.0.0
20:25:07.303 -> [63693] Connecting to 144.31.0.0
20:25:13.677 -> [70040] Connecting to 144.31.0.0
20:25:48.771 -> [565] Connected to WiFi
20:25:48.771 -> [565] IP: 192.168.137.223
20:25:48.771 -> ___ __ __
20:25:48.771 -> / _ )/ /_ _____ / /__
20:25:48.771 -> / _ / / // / _ \/ '_/
20:25:48.771 -> /____/_/\_, /_//_/_/\_\
20:25:48.771 -> /___/ v1.0.0-beta.1 on NodeMCU
20:25:48.771 ->
20:25:48.771 -> [572] Connecting to 80.0.0.0
20:25:54.958 -> [6737] Connecting to 80.0.0.0
20:26:01.193 -> [12973] Connecting to 80.0.0.0
20:26:07.521 -> [19317] Connecting to 80.0.0.0
20:26:13.850 -> [25659] Connecting to 80.0.0.0
20:26:20.225 -> [32002] Connecting to 80.0.0.0
20:26:26.551 -> [38340] Connecting to 80.0.0.0
20:26:32.871 -> [44682] Connecting to 80.0.0.0
20:26:39.246 -> [51030] Connecting to 80.0.0.0
20:26:45.576 -> [57373] Connecting to 80.0.0.0
20:26:51.905 -> [63720] Connecting to 80.0.0.0
20:26:58.268 -> [70072] Connecting to 80.0.0.0
20:27:04.625 -> [76410] Connecting to 80.0.0.0
20:27:10.976 -> [82749] Connecting to 80.0.0.0
20:27:17.308 -> [89097] Connecting to 80.0.0.0
20:27:23.646 -> [95437] Connecting to 80.0.0.0
20:27:29.976 -> [101777] Connecting to 80.0.0.0
20:27:36.340 -> [108118] Connecting to 80.0.0.0
20:27:42.573 -> [114363] Connecting to 80.0.0.0
20:27:48.855 -> [120631] Connecting to 80.0.0.0
20:27:55.028 -> [126832] Connecting to 80.0.0.0
20:28:01.252 -> [133051] Connecting to 80.0.0.0
20:28:07.610 -> [139395] Connecting to 80.0.0.0
20:28:13.948 -> [145736] Connecting to 80.0.0.0
20:28:20.256 -> [152075] Connecting to 80.0.0.0
20:28:26.613 -> [158412] Connecting to 80.0.0.0
20:28:32.968 -> [164757] Connecting to 80.0.0.0
20:28:39.282 -> [171094] Connecting to 80.0.0.0
20:28:45.647 -> [177434] Connecting to 80.0.0.0
20:28:51.987 -> [183775] Connecting to 80.0.0.0
20:28:58.316 -> [190114] Connecting to 80.0.0.0
20:29:04.550 -> [196335] Connecting to 80.0.0.0
20:29:09.960 -> [201754] Connecting to 80.0.0.0
20:29:14.938 -> [206754] Connecting to 80.0.0.0
20:29:21.113 -> [212914] Connecting to 80.0.0.0
20:29:27.417 -> [219202] Connecting to 80.0.0.0
20:29:33.724 -> [225537] Connecting to 80.0.0.0
20:29:40.065 -> [231879] Connecting to 80.0.0.0
20:29:46.413 -> [238226] Connecting to 80.0.0.0
20:29:52.771 -> [244564] Connecting to 80.0.0.0
20:29:59.106 -> [250905] Connecting to 80.0.0.0
20:30:05.429 -> [257246] Connecting to 80.0.0.0
20:30:11.789 -> [263584] Connecting to 80.0.0.0
