Hello, my project is to open the garage doors with the google voice assistant, my project works correctly with android.
But with Iphone IOS the buttons of the blynk app remain activated.
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"; //nodemcu test
char ssid[] = "SIDD";
char pass[] = "PASSW";
BLYNK_WRITE(V0)
int value = param.asInt(); // Get value as integer
if (value == 1)
digitalWrite(16, HIGH); // Set GPIO 16 HIGH
timer.setTimeout(500L, []() { // Run after 0.5 seconds second
digitalWrite(16, LOW); // Set Pin 16 LOW
Blynk.virtualWrite(V0, 0);
}); // END Timer Function
BLYNK_WRITE(V1)
if (value == 1)
digitalWrite(14, HIGH); // Set GPIO 14 HIGH
digitalWrite(14, LOW); // Set Pin 14 LOW
Blynk.virtualWrite(V1, 0);
pinMode(16, OUTPUT); //D4 is GPIO 16 (Cancello Grande RELE IN1)(RELAY BUTTON)
digitalWrite(16, LOW); // Set GPIO 16 HIGH
pinMode(14, OUTPUT); //D5 is GPIO 14 (Cancello Piccolo RELE IN2)(RELAY BUTTON)
digitalWrite(14, LOW); //Set GPIO 14 HIGH
timer.run ();
