Blynk HTTP RESTful API Time Input
Hi there,
I was wondering how the data structure of the time input widget is when I read it over the http restful api.
I tried it with a web browser and this was the answer:
["3600�-1�Europe/Rome�1,2,3�3600"]
What are these diamond symbol with the “?” in it?
Thanks and regards
Details can be found at Specials (Unicode block) - Wikipedia
Thanks for your quick response.
My problem is that the Arduino Uno Wifi which I am using is interpreting the Replacement character wrongly.
I am using it with the Ciao Library because it is the only option for that device. If I try to read the virtual pin pointing to my time input widget I get back only the first 4 characters until the first replacement character.
Has someone an idea what the problem could be?
Here is my code:
#include <Wire.h>
#include <Ciao.h>
#define CONNECTOR     "rest" // define connector type for the Ciao Library
#define SERVER_ADDR   "46.101.143.225" // blynk-clud.com IP address
  Ciao.begin();
  Ciao.println("WiFi connected");
  Serial.print("Reading value: ");
  String rcommand = String("/") + auth + "/get/V2";
  CiaoData rdata = Ciao.read(CONNECTOR, SERVER_ADDR, rcommand);
  String rvalue = String(rdata.get(2));
  Serial.println(rvalue);
  Ciao.println("Reading V2: "+ rvalue);
  delay(50);
