Hi
i have problem with code when i use arduino mega and hardware serial everythings is ok but i need to use arduino nano in my project. when i use nano in project the code freeze in void setup>Blynk.begin.
note : when i deleted simpletimer or blynk timer from code sim800 can connect to server.
please help how i can fix this problem.
thanks.
#define TINY_GSM_MODEM_SIM800
#define BLYNK_HEARTBEAT 10
#include <TinyGsmClient.h>
#include <TinyGPS++.h>
char auth[] = "*******************************"; //Your Project authentication key
char apn[] = "*************";
char user[] = "";
char pass[] = "";
const int GSMrxPin = 9;
const int GSMtxPin = 10;
SoftwareSerial SerialAT(GSMrxPin, GSMtxPin); // RX, TX
const int GPSrxPin = 7;
const int GPStxPin = 8;
SoftwareSerial GPSSerial(GPSrxPin, GPStxPin); // RX, TX
#define SerialAT Serial1
#define GPSSerial Serial2
const int GSMBaud = 9600;
const int GPSBaud = 9600;
const int ResetPin = 2;
const int move_index = 1; // fixed location for now
unsigned int spd; //Variable to store the speed
unsigned int sats; //Variable to store no. of satellites response
String bearing; //Variable to store orientation or direction of GPS
TinyGPSPlus gps; // The TinyGPS++ object
TinyGsm modem(SerialAT);
WidgetMap myMap(V0); // V0 for virtual pin of Map Widget
ResetVoid();
delay(100);
GPSSerial.begin(GPSBaud);
delay(100);
SerialAT.begin(GSMBaud);
delay(100);
modem.restart();
timer.setInterval(5000L, checkGPS); // every 5s check if GPS is connected, only really needs to be done once
void checkGPS(){
if (gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
Blynk.virtualWrite(V4, "GPS ERROR"); // Value Display widget on V4 if GPS not detected
void ResetVoid(){
digitalWrite(ResetPin, HIGH);
digitalWrite(ResetPin, LOW);
void displayInfo()
if (gps.location.isValid() )
float latitude = (gps.location.lat()); //Storing the Lat. and Lon.
float longitude = (gps.location.lng());
Serial.print("LAT: ");
Serial.println(latitude, 6); // float to x decimal places
Serial.print("LONG: ");
Serial.println(longitude, 6);
Blynk.virtualWrite(V1, String(latitude, 6));
Blynk.virtualWrite(V2, String(longitude, 6));
myMap.location(move_index, latitude, longitude, "Peugeot 207");
spd = gps.speed.kmph(); //get speed
Blynk.virtualWrite(V3, spd);
sats = gps.satellites.value(); //get number of satellites
Blynk.virtualWrite(V4, sats);
bearing = TinyGPSPlus::cardinal(gps.course.value()); // get the direction
Blynk.virtualWrite(V5, bearing);
while (GPSSerial.available() > 0)
// sketch displays information every time a new sentence is correctly encoded.
if (gps.encode(GPSSerial.read()))
displayInfo();
