The param.asInt on V9 is a numeric input widget with a time of 0 - 120min. The idea is to get the info and turn it into millis to be used elsewhere. On the serial monitor it shows a 0 value although on the app the widget has been set to 2min. Can someone please explain why is that?
BLYNK_WRITE(V9) //CH1 FADEIN TIME WIDGET
FadeIN = param.asInt();
FadeInTime == (FadeIN * 60000); //Param is in minutes
//FadeInTime = map(FadeIN, 0, 120, 0, 7200000); //2 hour max fade duration
Serial.print("LedFadeIn Time: ");
Serial.println(FadeInTime);
