Blynk fade example
good morning friends … i would like to use this code in a project and i would like to know if you can add a blynk button to the fade example
and would you like to put on a top to stay lit?
for example: a physical push button is triggered and the lamp turns on for 1 minute then turns off
I tried to add a button in this code, but without success, the lamp is always on :frowning:
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  Fade using a LED widget on your phone!
  App project setup:
    LED widget on V2
char pass[] = "YourPassword";
WidgetLED led2(V2);
// V2 LED Widget is fading
void fadeLedWidget()
  static int value = 0;
  static int delta = 30;
  value += delta;
  if (value > 255 || value < 0) {
    delta = -delta;
    Serial.print("LED on V2: ");
    Serial.println(value);
    led2.setValue(value);
  timer.setInterval(300L, fadeLedWidget);
