Hello. I’m just testing examples and I’ve encountered some problems.
I use arduino uno and ESP8266-01.
I’ve uploaded the terminal example. Works great. Then I added elements from the Get Data ‘(BLYNK_WRITE(V1))’ and Push Data (Blynk.virtualWrite(V5, millis() / 1000) with Blynk timer examples. All these elements separatly work well. However, after the merger I can not get a connection with Blynk. (internet works). any help?
and a question. functions such as Blynk.connect or Blynk.syncAll (); can only be called from setup after reset board? or from anywhere after ESP power restore?
Thank you
#include <ESP8266_Lib.h>
#include "WiFiEsp.h"
#include "SoftwareSerial.h"
SoftwareSerial Serial1(2, 3); // RX, TX
ESP8266 wifi(&Serial1);
char ssid[] = "NA****"; // your network SSID (name)
char pass[] = "**GFia***t"; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
char auth[] ="e933****6b0755295e8efa";
bool Connected2Blynk;
WidgetTerminal terminal(V1);
BLYNK_WRITE(V10)
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("V10 Slider value is: ");
Serial.println(pinValue);
BLYNK_WRITE(V1)
// if you type "Marco" into Terminal Widget - it will respond: "Polo:"
String strin=param.asStr();
Serial.println(strin);
if (strin==("Marco")) {
terminal.println("You said: 'Marco'") ;
terminal.println("I said: 'Polo'") ;
digitalWrite(13,HIGH) ;
else if (strin==("ela")){
terminal.println("You said: 'ela'") ;
digitalWrite(13,LOW);
// digitalWrite(13,HIGH) ;
else if(strin==("ala")){
Serial.println("odebrałem 'ala'");
digitalWrite(13,HIGH);
if (strin==("ewa")) {
terminal.println("You said: 'ewa'") ;
digitalWrite(13,LOW) ;
// Ensure everything is sent
terminal.flush();
void zegar10()
Blynk.virtualWrite(V3, millis() / 1000);
void printWifiData()
// print your WiFi shield's IP address
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print your MAC address
byte mac[6];
WiFi.macAddress(mac);
char buf[20];
sprintf(buf, "%02X:%02X:%02X:%02X:%02X:%02X", mac[5], mac[4], mac[3], mac[2], mac[1], mac[0]);
Serial.print("MAC address: ");
Serial.println(buf);
void printCurrentNet()
// print the SSID of the network you're attached to
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the MAC address of the router you're attached to
byte bssid[6];
WiFi.BSSID(bssid);
char buf[20];
sprintf(buf, "%02X:%02X:%02X:%02X:%02X:%02X", bssid[5], bssid[4], bssid[3], bssid[2], bssid[1], bssid[0]);
Serial.print("BSSID: ");
// print the received signal strength
long rssi = WiFi.RSSI();
Serial.print("Signal strength (RSSI): ");
Serial.println(rssi);
// initialize serial for debugging
// initialize serial for ESP module
Serial1.begin(9600);
// initialize ESP module
WiFi.init(&Serial1);
// check for the presence of the shield
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue
while (true);
// attempt to connect to WiFi network
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network
status = WiFi.begin(ssid, pass);
Serial.println("You're connected to the network");
Blynk.config(wifi,auth);
Serial.println("Attempting to BLYNK");
Blynk.connect();
Connected2Blynk = Blynk.connected();
if(Connected2Blynk){
Serial.println("połączone z BLYNK");}
else{
Serial.println("NIEEEEEEE połączone z BLYNK");
Serial.println();
printCurrentNet();
printWifiData();
timer.setInterval(5000L, zegar10);
pinMode(13,OUTPUT);
pinMode(8,INPUT);
} //setup end
Blynk.run();}
} //loop end
this simple code does not work either:
#define BLYNK_DEBUG // Optional, this enables lots of prints
char auth[] = "e933e7c5dafswert5295e8efa";
int a0;
long a1;
long a2;
String strin = "";
char ssid[] = "NAxGA"; // your network SSID (name)
char pass[] = "Kxxat"; // your network password
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
void terminCzytaj(){
else if (strin==("ewa")) {
int u=13;
terminal.print("flaga SW :");
terminal.println(u,BIN);
terminal.flush();
BLYNK_WRITE(V1)
terminal.flush();
terminCzytaj();
void myTimerEvent()
Blynk.virtualWrite(V3,a1);
Blynk.virtualWrite(V4,a2);
//Blynk.virtualWrite(V11, a0);
BLYNK_WRITE(V10)
BLYNK_WRITE(V9)
Serial.print("V9 button value is: ");
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
timer.setInterval(3000L, myTimerEvent);
pinMode (13,OUTPUT);
a0=analogRead(A0);
a1=millis() / 1000;
a2=millis() / 2000;
