I am using the CC3000 with the Arduino Uno. I tested CC3000 wifi already, and I am using codebender to use the Blynk example sketch to turn on an LED. But, it won’t compile, and there is no errors appearing. The authorization token is the correct.
``` cpp <--put 3 backticks BEFORE your code starts (cpp means C++ language)
//Put your code here
``` <--insert 3 backticks AFTER your code
**This makes your code readable and with highlighted syntax, like this:**
This example shows how to use Adafruit CC3000 breakout
to connect your project to Blynk.
For this example you need Adafruit_CC3000_Library library:
https://github.com/adafruit/Adafruit_CC3000_Library
Note: Firmware version 1.14 or later is preferred.
1. Update pin definitions according to your setup.
2. Change WiFi ssid, pass, and Blynk auth token
Run
// These are the interrupt and control pins for СС3000
define ADAFRUIT_CC3000_IRQ 3
define ADAFRUIT_CC3000_VBAT 5
define ADAFRUIT_CC3000_CS 10
include
include
include
char auth[] = "XXXXXXXXXXXXXXXXXXXXXXX";
// Choose wifi_sec from WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
char ssid[] = "wifi_ssid";
char pass[] = "wifi_pass";
int wifi_sec = WLAN_SEC_WPA2;
Blynk.begin(auth, ssid, pass, wifi_sec);
Sorry about that. I do have the libraries under my personal libraries in codebender.
