hi @PeteKnight i think there is a problem in my else if command because after sending the notification one time, i tried to jumpwire an led on the output to ground to check if the pir sensor is high or low, the flag command is not being reset because i saw that the led stopped lighting up but the comment Motion is now absent and New motion detection events will trigger a new alert notification is not sent in the serial.
can you help me? thankyou
The existing serial print statements should show you whether the if statements are evaluating as true - when the do the serial print statements inside the if statements will print to the serial monitor.
If youāre not sure why the if statements arenāt giving the results you expect then add more serial print commands to print the values of various variables that you are using in your if comparisons. Put tehse in your MotionSensorTimer just after this line of code:
Hi @PeteKnight thankyou for the fast response, iāve just reflashed the same code and it seems to be working but the problem now is the āMotion is now absentā and āNew motion detection events will trigger a new alert notificationā is flooding the serial monitor where as the notification has been sent is only triggered once
iāve just checked i added ā;ā after the
else if(sensor = MotionSensor && alert_sent == true)
that might be the reason why it is alternating from no detected to motion detected.
i got flagged again after adding " ; " which means that the flag does not work after adding the ;
i might try again tomorrow
Not without your fill sketch and the info that appears in your serial monitor, and som additional information explaining what you were doing at the time so that the serial data makes some sense.
hi @PeteKnight
this is my whole sketch
#define BLYNK_TEMPLATE_ID "REDACTED"
#define BLYNK_DEVICE_NAME "REDACTED"
#define BLYNK_AUTH_TOKEN "REDACTED"
#include <DHT.h>
char auth[] = "REDACTED";
char ssid[] = "REDACTED"; //Enter your WIFI Name
char pass[] = "REDACTED"; //Enter your WIFI Password
int Status = 12; // Digital pin D6
int sensor = 13; // Digital pin D7
float MotionSensor = LOW; // We will send an alert if the sensor outputs HIGH
bool alert_sent = false; // Flag to track if an alert has been sent for a motion detected event
BlynkTimer timer; // This function creates the timer object. It's part of Blynk library
void MotionSensorTimer()
float sensor = digitalRead(13);
Blynk.virtualWrite(V0, sensor);
if(sensor != MotionSensor && alert_sent == false)
Blynk.logEvent("motion_detected"); // trigger the notification
alert_sent = true; // set the flag to indicate that an alert has been sent for this motion detected situation
Serial.println("Blynk Alert Notification sent!");
Serial.println();
alert_sent = false; // reset the flag so that a future motion detection situation will trigger an alert
Serial.println("Motion is now absent");
Serial.println("New motion detection events will trigger a new alert notification");
Serial.println();
//Connecting to Blynk Cloud
// Setting interval to send data to Blynk Cloud to 1000ms.
// It means that data will be sent every second
timer.setInterval(10000L, MotionSensorTimer); // take a reading from the PIR sensor every 10 seconds
after turning on the ESP8266 or nodemcu, i am greeted with
after that blynk alert notification sent, it wont show that the motion is absent and that new motion will trigger the event. and after receiving the first notification, i wont receive anymore notification which justifies that the alert_sent is not being resetted which blocks any notifications anymore.
also, iāve tried to walk out in the room in order to check if the sensor will reset or reads a low value to make motion absent but it wont.
please disregard the dht library since i will add it later on after i figure out this pir sensor :))
Okay, I expected to see a sketch where youād taken my advice and added additional serial print statements, and the values of your variables appearing in the serial monitor as a result.
Without that info Iām as much in the dark as you are.
Also, when you share serial output data please copy the text from your serial monitor and paste it, using triple backticks, into the forum rather than posting screenshots.
Hi @PeteKnight iāve now just understand what you mean by adding more serials after the float. Im trying it now and will update what happens. Thankyou verymuch for you patience in helping me :))
@PeteKnight hereās what happened:
hereās the code that iāve used
#include <DHT.h>
float MotionSensor = 0; // We will send an alert if the sensor outputs HIGH
Serial.print("sensor = ");
Serial.println(digitalRead(13));
if(sensor = 1 && alert_sent == false)
Serial.println();
else if(sensor = 0 && alert_sent == true)
Serial.println();
and heres the output in serial monitor
[6393] IP: 192.168.1.130
[6393]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.1.0 on ESP8266
#StandWithUkraine https://bit.ly/swua
[6519] Connecting to blynk.cloud:80
[6653] Ready (ping: 40ms).
sensor = 1
sensor = 1
sensor = 1
sensor = 0
sensor = 0
sensor = 0
sensor = 0
sensor = 0
sensor = 0
sensor = 1
sensor = 1
sensor = 1
sensor = 1
sensor = 1
sensor = 1
sensor = 1
sensor = 1
here in my code, i put when sensor is = 1, it will send a notification and set the alert_sent = true and in the else if, i put that if the sensor is 0, it will set the alert_sent to false. and send a message in the serial that motion is now absent and new motion detection events will trigger a new alert notification. but in the serial monitor, the first reading of sensor = 1 sent the blynk alert notification sent message but when it became = 0, it didnt sent the motion is now absent. which makes me believe that the alert_sent is not working properly
hi @PeteKnight
i have it working now. i get what you mean now and it is now working properly. i will test it tomorrow with real time notification. but in the serial monitor, i am assuming that it is working now
this is the code that i have been using now
#include <DHT.h>
if(sensor > MotionSensor && alert_sent == false)
Serial.println();
else if(sensor <= MotionSensor && alert_sent == true)
Serial.println();
and this is the output in the serial monitor
[6393] Connected to WiFi
[6394] IP: 192.168.1.130
[6394]
___ __ __
[6850] Ready (ping: 37ms).
sensor = 1
sensor = 1
sensor = 0
sensor = 1
thankyou for all your help and patience :)))
Well, first of all, this:
should say:
Serial.println(sensor);
because youāve already done a digital read on pin 13 and saved the value to sensor and it is this value, not any subsequent digital read results, that will be used in the if statement.
but, there are three variables used in your if/else statements and to fully understand why a particular if/else statement is evaluating as true you need to serial print all of them, not just one.
Hi @PeteKnight Thankyou for pointing that out. iāll make sure to change it and will update tomorrow if the notification is working properly.
Thanks!
Hi @PeteKnight
the code seems to work properly and i am getting the desired output. thankyou very much for all the help and patience. I learned a lot from this discussion thankyou!!
