Can I access the blynk project I made with ethernet from anywhere in the world or can I only access it from my home network?
If you’re using the Blynk cloud servers then anywhere in the world.
If you’re using a local server then it depends on how you’ve configured your router, and also on your ISP.
I not used Blynk very much. How can i use “Cloud”?
Cloud is the default.
Thanks .
