Blynk+esp8266+DHT22
Hello I tryed this project code, work on my smartphone android and I’ve two value display
umidity and temperature.
//#define BLYNK_DEBUG
#include <ESP8266_HardSer.h>
#include <BlynkSimpleShieldEsp8266_HardSer.h>
#include <DHT.h>
#define DHTTYPE DHT22
#define DHTPIN A0
DHT dht(DHTPIN, DHTTYPE, 30);
float humidity, temp_f;  // Values read from sensor
// Set ESP8266 Serial object
#define EspSerial Serial
ESP8266 wifi(EspSerial);
char auth[] = "9adaa1fd29494e168b760f6fb257fd11";
WidgetLED led1(0);
  // Set console baud rate
  // Set ESP8266 baud rate
  EspSerial.begin(115200);
  Blynk.begin(auth, wifi, "WiFi", "12345678901234567890");
  dht.begin();           // initialize temperature sensor
BLYNK_READ(0) // Led at V0 as Input
if (digitalRead(13) == HIGH) { // if your digital input is high
led1.on();
led1.off();
BLYNK_READ(1)
temp_f = dht.readTemperature(false)- 1.8;// Read temperature as Celsius
int value=temp_f*10;
String str;
char result[5];
result[0]=(value/100)+'0';
result[1]=((value/10)%10)+'0';
result[2]='.';
result[3]=(value%10)+'0';
result[4]='\0';
str +=result;
str +="℃";
//char buf[str.length()+1];
char buf[8];
str.toCharArray(buf,sizeof(buf));
Blynk.virtualWrite(1,buf);
BLYNK_READ(2)
humidity = dht.readHumidity();           // Read humidity (percent)
int value=humidity*10;
String str;
char result[5];
result[2]='.';
result[4]='\0';
str +=result;
str +="%";
char buf[8];
Blynk.virtualWrite(2,buf);
I need insert in my project
temperature graph (Graph Setting botton on smartphone)
how is possible it?
The widget History Graph 8.9 virtual pin connection data DHT22.
//#define BLYNK_PRINT Serial    // Comment this out to     disable prints and save space
    char auth[] = "------------";
    #include <DHT.h>
    #define DHTPIN 12 //pin gpio 12 in sensor
    DHT dht(DHTPIN, DHTTYPE);
void sendUptime()
  float h = dht.readHumidity();
  t = ((int) (t * 10) / 10.0);
  h = ((int) (h * 10) / 10.0);
  Blynk.virtualWrite(8, t); // virtual pin
  Blynk.virtualWrite(9, h); // virtual pin
  Blynk.begin(auth, "wifi", "pass");
  dht.begin();
  timer.setInterval(10000, sendUptime);//1000=1s
Why is necessary this line? h = ((int) (h * 10) / 10.0);
Couldnt use just h ?
@alvaroaguero55 I know it’s not easy to always tell on the forum but the last post for this thread was 15th Dec 2015. Over a year ago, and as the libraries keep changing then anything older than a month or two is out of date and causes lots of problems when Blynkers try to use the sketches.
The line you refer to is a common coding “hack” relating to integers / floats and rounding etc. The 10.0 is the significant part.
