Blynk + ESP8266-01+SoftSerial example problems
I have been experimenting with an ESP8266-01 and have uploaded the Shield_SoftSerial example sketch.
I get the following information from the serial monitor which suggests that my Arduino is connecting to my WiFi.
[19] Blynk v0.3.5-beta on Arduino Nano
[520] Connecting to VM610300-2G
[5670] IP: +CIFSR:STAIP,"105.71.85.69"
+CIFSR:STAMAC,"18:fe:34:dc:ff:10"
OK
[5805] Connected to WiFi
However, if I look at the devices connected in my router settings I don’t see this IP or MAC listed.
Also, if I start the Blynk App on my phone it says “Your Arduino Nano is not in the network”.
Any help would be great.
Did you try troubleshooting section in the docs?
I have resolved this issue by uploading the bare minimum example in to the Arduino Nano and then using the following AT command to manually set the ESP8266 IP:
AT+CIPSTA=<IP>[,<gateway>,<netmask>]"
and using the gateway and netmask values on my network.
Although this resolved the connectivity issue, I tried to use the SimpleTimer library to get some feedback from my Nano’s output pins and the Arduino would constantly disconnect and reconnect to the network.
