Blynk energy monitoring via serial interface
I have loaded following sketch into my arduino Uno board.
I dont have ethernet of wifi shield so,I want to read my data via serial interface.
So,please help me out how to do in windows desktop so,that i can read sensor values in my blynk app
    This sketch sends ads1115 current sensor data via HTTP POST request to thingspeak server.
    It needs the following libraries to work (besides the esp8266 standard libraries supplied with the IDE):
    - https://github.com/adafruit/Adafruit_ADS1X15
    designed to run directly on esp8266-01 module, to where it can be uploaded using this marvelous piece of software:
    https://github.com/esp8266/Arduino
    2015 Tisham Dhar
    licensed under GNU GPL
#include <FS.h> //this needs to be first, or it all crashes and burns..
#if PLATFORM_ID == 88
#include "application.h"
#else
#include <Wire.h>
#endif
//#define Serial SerialUSB
//#define Serial Serial1
  #if defined(ARDUINO)
  SYSTEM_MODE(MANUAL);//do not connect to cloud
  #else
  SYSTEM_MODE(AUTOMATIC);//connect to cloud
  #endif
#include <Adafruit_ADS1015.h>
#include <Adafruit_NeoPixel.h>
#include <DNSServer.h>            //Local DNS Server used for redirecting all requests to the configuration portal
#include <ESP8266WebServer.h>     //Local WebServer used to serve the configuration portal
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager WiFi Configuration Magic
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
char auth[36] = "YOUR_BLYNK_TOKEN";
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
bool notifyFlag = false;
#define VIRTUAL_EN_PUSH V0
#define VIRTUAL_POWER   V1
#define VIRTUAL_VOLTAGE V2
#define VIRTUAL_CURRENT V3
#define VIRTUAL_LCD     V4
#define VIRTUAL_PF      V5
WidgetLCD lcd(VIRTUAL_LCD);
bool pushEnabled = false;
// Hardware Definitions //
const int LED_PIN = 5;
const int RGB_PIN = 4;
Adafruit_NeoPixel rgb = Adafruit_NeoPixel(1, RGB_PIN, NEO_GRB + NEO_KHZ800);
void setLED(uint8_t red, uint8_t green, uint8_t blue);
#ifdef ESP8266
#include <pgmspace.h>
#else
#include <avr/pgmspace.h>
#endif
Adafruit_ADS1115 ads;  /* Use this for the 16-bit version */
//Maximum value of ADS
#define ADC_COUNTS 32768
#define PHASECAL 1.7
#define VCAL 0.8
#define ICAL 0.04
double filteredI;
double lastFilteredV, filteredV; //Filtered_ is the raw analog value minus the DC offset
int sampleV;                 //sample_ holds the raw analog read value
int sampleI;
double offsetV;                          //Low-pass filter output
double offsetI;                          //Low-pass filter output
//Scaling for final calibration
double vmult = 1.0, imult = 1.0, phmult = 1.0;
double realPower,
       apparentPower,
       powerFactor,
       Vrms,
       Irms;
double phaseShiftedV; //Holds the calibrated phase shifted voltage.
int startV; //Instantaneous voltage at start of sample window.
double sqV, sumV, sqI, sumI, instP, sumP; //sq = squared, sum = Sum, inst = instantaneous
boolean lastVCross, checkVCross; //Used to measure number of times threshold is crossed.
double squareRoot(double fg)
  double n = fg / 2.0;
  double lstX = 0.0;
  while (n != lstX)
    lstX = n;
    n = (n + fg / n) / 2.0;
  return n;
void calcVI(unsigned int crossings, unsigned int timeout)
  unsigned int crossCount = 0;                             //Used to measure number of times threshold is crossed.
  unsigned int numberOfSamples = 0;                        //This is now incremented
  // 1) Waits for the waveform to be close to 'zero' (mid-scale adc) part in sin curve.
  boolean st = false;                                //an indicator to exit the while loop
  unsigned long start = millis();    //millis()-start makes sure it doesnt get stuck in the loop if there is an error.
    while(st==false)                                   //the while loop...
     startV = ads.readADC_Differential_2_3();                    //using the voltage waveform
     if ((startV < (ADC_COUNTS*0.6)) && (startV > (-ADC_COUNTS*0.6))) st=true;  //check its within range
     if ((millis()-start)>timeout) st = true;
  // 2) Main measurement loop
  start = millis();
  while ((crossCount < crossings) && ((millis() - start) < timeout))
    numberOfSamples++;                       //Count number of times looped.
    lastFilteredV = filteredV;               //Used for delay/phase compensation
    // A) Read in raw voltage and current samples
    sampleV = ads.readADC_Differential_0_1();                 //Read in raw voltage signal
    sampleI = ads.readADC_Differential_2_3();                 //Read in raw current signal
    // B) Apply digital low pass filters to extract the 2.5 V or 1.65 V dc offset,
    //     then subtract this - signal is now centred on 0 counts.
    offsetV = offsetV + ((sampleV - offsetV) / 1024);
    filteredV = sampleV - offsetV;
    offsetI = offsetI + ((sampleI - offsetI) / 1024);
    filteredI = sampleI - offsetI;
    // C) Root-mean-square method voltage
    sqV = filteredV * filteredV;                //1) square voltage values
    sumV += sqV;                                //2) sum
    // D) Root-mean-square method current
    sqI = filteredI * filteredI;                //1) square current values
    sumI += sqI;                                //2) sum
    // E) Phase calibration
    phaseShiftedV = lastFilteredV + PHASECAL * (filteredV - lastFilteredV);
    // F) Instantaneous power calc
    instP = phaseShiftedV * filteredI;          //Instantaneous Power
    sumP += instP;                              //Sum
    // G) Find the number of times the voltage has crossed the initial voltage
    //    - every 2 crosses we will have sampled 1 wavelength
    //    - so this method allows us to sample an integer number of half wavelengths which increases accuracy
    lastVCross = checkVCross;
    if (sampleV > startV) checkVCross = true;
    else checkVCross = false;
    if (numberOfSamples == 1) lastVCross = checkVCross;
    if (lastVCross != checkVCross) crossCount++;
  // 3) Post loop calculations
  //Calculation of the root of the mean of the voltage and current squared (rms)
  //Calibration coefficients applied.
  float multiplier = 0.125F; /* ADS1115 @ +/- 4.096V gain (16-bit results) */
  double V_RATIO = VCAL * multiplier;
  Vrms = V_RATIO * squareRoot(sumV / numberOfSamples);
  double I_RATIO = ICAL * multiplier;
  Irms = I_RATIO * squareRoot(sumI / numberOfSamples);
  //Calculation power values
  realPower = V_RATIO * I_RATIO * sumP / numberOfSamples;
  apparentPower = Vrms * Irms;
  powerFactor = realPower / apparentPower;
  //Reset accumulators
  sumV = 0;
  sumI = 0;
  sumP = 0;
void readBlynkConfig()
  //clean FS, for testing
  //SPIFFS.format();
  //read configuration from FS json
  //Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    //Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      //Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        //Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
          //Serial.println("\nparsed json");
          strcpy(auth, json["auth"]);
          //Serial.println("failed to load json config");
    //Serial.println("failed to mount FS");
  //end read
void saveBlynkConfig()
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    //Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["auth"] = auth;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      //Serial.println("failed to open config file for writing");
    json.printTo(configFile);
    configFile.close();
    //end save
void readMultConfig()
  //SPIFFS.format();
    if (SPIFFS.exists("/mult.json")) {
      File configFile = SPIFFS.open("/mult.json", "r");
      if (configFile) {
          vmult = json["vmult"];
          imult = json["imult"];
          phmult = json["phmult"];
  //end read
void saveMultConfig()
  //save the multiplier parameters to FS
  json["vmult"] = vmult;
  json["imult"] = imult;
  json["phmult"] = phmult;
  File configFile = SPIFFS.open("/mult.json", "w");
  if (!configFile) {
  configFile.close();
  //end save
  pinMode(LED_PIN, OUTPUT);
  digitalWrite(LED_PIN, LOW); // Turn off blue LED
  rgb.begin(); // Set up WS2812
  setLED(0, 0, 32); // LED blue
  ads.setGain(GAIN_ONE);        // 1x gain   +/- 4.096V  1 bit = 0.125mV
  ads.begin();
  Wire.begin();
  //Read previous config
  readBlynkConfig();
  readMultConfig();
  // The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  WiFiManagerParameter custom_blynk_token("blynk", "blynk token", auth, 33);
  //Use wifi manager to get config
  WiFiManager wifiManager;
  wifiManager.setDebugOutput(false);
  //set config save notify callback
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  //add all your parameters here
  wifiManager.addParameter(&custom_blynk_token);
  //first parameter is name of access point, second is the password
  wifiManager.autoConnect("Blynkwhatnick", "EnergyMonitor");
  //if you get here you have connected to the WiFi
  Serial.println("connected...yeey :)");
  //read updated parameters
  strcpy(auth, custom_blynk_token.getValue());
  saveBlynkConfig();
  // Initialize Blynk, and wait for a connection before doing anything else
  Serial.println("Connecting to Blynk Server");
  Blynk.config(auth);
  while (!Blynk.connected())
  Serial.println("Blynk connected! Energy monitor starting.");
  setLED(0, 32, 0); // LED green
  // init done
int lastTick = 0;
  if ((millis() - lastTick > 10000)) { //60000 - 1 minute
    measureVI();
    lastTick = millis();
    Serial.print("Vrms:");
    Serial.println(Vrms * vmult);
    Serial.print("Irms:");
    Serial.println(Irms * imult);
    Serial.print("Power:");
    Serial.println(realPower * vmult * imult);
    Serial.print("p.f.:");
    Serial.println(powerFactor * phmult);
  yield();
bool firstConnect = true;
BLYNK_CONNECTED()
  if (firstConnect) // When we first connect to Blynk
    // Two options here. Either sync values from phone to Blynk Board:
    //Blynk.syncAll(); // Uncomment to enable.
    // Or set phone variables to default values of the globals:
    Blynk.virtualWrite(VIRTUAL_POWER, realPower * vmult * imult);
    Blynk.virtualWrite(VIRTUAL_CURRENT, Irms * imult);
    Blynk.virtualWrite(VIRTUAL_VOLTAGE, Vrms * vmult);
    Blynk.virtualWrite(VIRTUAL_PF, powerFactor * phmult);
    // Print a splash screen:
    lcd.clear();
    lcd.print(0, 0, "Energy Monitor ");
    lcd.print(0, 1, "     Ready      ");
void measureVI()
  calcVI(20, 2000);
  // Write the values to Blynk:
BLYNK_WRITE(V6) //Button Widget is writing to pin V6
  int pinData = param.asInt();
  vmult = pinData / 100.0f;
  Serial.print("V Mult: ");
  Serial.println(vmult);
  saveMultConfig();
BLYNK_WRITE(V7) //Button Widget is writing to pin V7
  imult = pinData / 100.0f;
  Serial.print("I Mult: ");
  Serial.println(imult);
  saveMultConfig();
BLYNK_WRITE(V8) //Button Widget is writing to pin V8
  phmult = pinData / 100.0f;
  Serial.print("Phase Mult: ");
  Serial.println(phmult);
  saveMultConfig();
  rgb.setPixelColor(0, rgb.Color(red, green, blue));
  rgb.show();
You can use the USB link to connect your UNO to Blynk’s Cloud Server - http://docs.blynk.cc/#hardware-set-ups-arduino-over-usb-no-shield
There is a video demonstration here - Arduino Uno and USB step by step tutorial
Also I formatted you posted code so we can see it clearly. Please look back at your post to see how that was done.
