Blynk.email (“mail”, “Subject”, “Text”)
Hi all.
Do you know if it is possible to add the shipment to more than one email, using the same command "Blynk.email?
Hi all.
If I understand your request correctly… yes, sorta… just process multiple email commands with different addresses.
void emailprocess() {
Blynk.email (“mail1”, “Subject”, “Text”)
Blynk.email (“mail2”, “Subject”, “Text”)
Blynk.email (“mail3”, “Subject”, “Text”)
Although if you have more then a couple at a time, you might want to use a tiler setup to spread them out.
EDIT - I use Local Server, so the above might work for me (untested) but not on Cloud Server due the 1 email per 5 seconds rule… so a timeout timer is a must…
Blynk.email (“mail1”, “Subject”, “Text”) // Send now
// Timed Lambda Function
timer.setTimeout(5500L, []() { // Send in 5.5 seconds
}); // END Timer Function
timer.setTimeout(11000L, []() { // Send in 11 seconds
This is just one way of doing something like this… one could take an array of addresses and run a more sophisticated timed routine to increment the address, etc… but please no spamming
