Blynk Edgent,
Hello guys.
I need help with coding.
I have upload the blynkEdgent code onto the ESP 8266, activated the device and connected to Blynk.
Now I am facing a problem, as I would like to add my own code to measure temperature using the DS18b20.
Where should I write the code?
In the .ino file.
You’ll probably need to add a BlynkTimer to call the function that takes the temperature readings, and add a time.run() line to your void loop.
