Dear Blynk Community Members, I’m new to blank and find it very interesting and trying many different things.
I want to make an Incubator and want to get an e-mail notification only ONCE if Temp < 30 or Temp > 40 or Humidifity < 40%.
I wrote (basically modify) the following code. With this code I’m getting multiple (every 20 seconds)
#include <DHT.h>
char auth[] = "***"; //Enter the Auth code which was send by Blink
char ssid[] = "***"; //Enter your WIFI Name
char pass[] = "***"; //Enter your WIFI Password
#define DHTPIN 2 // Digital pin 4
#define LITEPIN1 D1 //Light 1
#define LITEPIN2 D2 //Light 2
//Register Light to virtual pin 1 (V1)
WidgetLED led1(V1); //Virtual Pin V1 for light ON/OFF
//Register Light to virtual pin 2 (V2)
WidgetLED led2(V2); //Virtual Pin V1 for Humidity
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
Serial.println(t);
Serial.println(h);
if (t <= 37.5) // the temperature in your incubator should be maintained between 37 and 39 degrees Celcius.
digitalWrite(LITEPIN1,LOW);
digitalWrite(LITEPIN2,LOW);
led1.on();
Serial.println("Lights are ON");
digitalWrite(LITEPIN1,HIGH);
digitalWrite(LITEPIN2,HIGH);
led1.off();
Serial.println("Lights are OFF");
if (h <= 40) //The humidity levels should be between 50 and 55% and then increase to about 65% for the final three days of incubation.
led2.on();
Serial.println("Low Humidity");
Blynk.email("my_email@hotmail.com", "Subject: Low Humidity", "Humidity level is low");
led2.off();
Serial.println("Humidity Level is OK");
if (t > 40) // You can write any condition to trigger e-mail sending
Serial.println("Temperature is higher than 40oC"); // This can be seen in the Serial Monitor
Blynk.email("my_email@hotmail.com", "Subject: High Temp", "Temp is > 40");
if (t < 30) // You can write any condition to trigger e-mail sending
Serial.println("Temperature is Low than 30oC"); // This can be seen in the Serial Monitor
Blynk.email("my_email@hotmail.com", "Subject: Low Temp", "Temp is < 30");
delay(20000);
// Send e-mail when your hardware gets connected to Blynk Server
// Just put the recepient's "e-mail address", "Subject" and the "message body"
Blynk.email("my_email@hotmail.com", "Subject: Blynk is Online", "hardware gets connected to Blynk Server");
dht.begin();
pinMode (LITEPIN1, OUTPUT);
pinMode (LITEPIN2, OUTPUT);
