Blynk double connect with deep sleep
  1. My wake times to connect, send one value and return to sleep were too long (aprox 10 seconds)
  2. I shortened some of the 5000 delays in the library to 1000 per suggestions on board and got it down to 3-5 sec
  3. With the debug ON you can see a 2nd connect message. (duplicate?)
Here is what I get now as output.
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v3de0c112
~ld
~+⸮⸮⸮Connecting to cxxxxxx
[1274] Connected to WiFi
[1274] IP: 192.168.86.26
[1274]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.4.8 on NodeMCU
[1283] Free RAM: 45696
[1286] Connecting to blynk-cloud.com:8442
[1447] <[02|00|01|00] 7df9c35910e242958b41cdfd423a24f1
[1549] >[00|00|01|00|C8]
[1549] Ready (ping: 1ms).
[1549] <[11|00|02|00]Hver[00]0.4.8[00]h-beat[00]10[00]buff-in[00]1024[00]dev[00]NodeMCU[00]build[00]Oct 22 2017 07:36:31[00]
[1651] >[00|00|02|00|C8]
[2550] Connecting to blynk-cloud.com:8442
[2670] <[02|00|01|00] 7df9c35910e242958b41cdfd423a24f1
[2776] >[00|00|01|00|C8]
[2776] Ready (ping: 1ms).
[2776] <[11|00|02|00]Hver[00]0.4.8[00]h-beat[00]10[00]buff-in[00]1024[00]dev[00]NodeMCU[00]build[00]Oct 22 2017 07:36:31[00]
[2890] >[00|00|02|00|C8]
72.50
[3233] <[14|00|03|00|0C]vw[00]10[00]72.500
total time : 3097
Looks like a double connect (one second apart)
Here is my code snippet :
#define BLYNK_DEBUG
#include <Arduino.h>
extern "C" {
#include <user_interface.h>
/* DS18B20 Temperature Sensor */
#include <OneWire.h>
#include<DallasTemperature.h>
#define ONE_WIRE_BUS 2 // DS18B20 on arduino pin2 corresponds to D4 on physical board - GPIO02
DallasTemperature DS18B20(&oneWire);
float tempF;
unsigned long starttime;
// how long to sleep between checking and TX temp/batt values - in seconds
#define SLEEP_LENGTH 60
// Blynk auth
char auth[] = "xxxxxxxxxxxxxxxxxxf1";
/* WiFi credentials */
char ssid[] = "cxxxxxxx";
char pass[] = "xxxxxxxxxxx";
  Serial.begin(74880); // default wake up baud after rst
  starttime=millis();
  // rst_info *rinfo = ESP.getResetInfoPtr();
  // Serial.println(String("\nResetInfo.reason = ") + (*rinfo).reason + ": " + ESP.getResetReason() + "\n");
    Serial.print("atempting Conection"); //Wait until connected
  //do work here.......
  DS18B20.begin();
  DS18B20.setResolution(10);
  DS18B20.requestTemperatures();
  tempF = DS18B20.getTempFByIndex(0);
  Serial.println(tempF);
  Blynk.virtualWrite(10, tempF); //virtual pin V10
  Serial.print("total work time : ");
  Serial.println(millis()-starttime);
  ESP.deepSleep(SLEEP_LENGTH * 1000000,WAKE_RF_DEFAULT);   // default mode
  delay(100);
 //do nothing here. The Setup() function takes care of it all as the ESP resets each time after it wakes from sleep
Can anyone figure why the 2nd connect is happening…?
please edit your post and format the code properly before posting. otherwise no one will bother to read it.
@doronby I fixed your formating… please use this method yourself in the future.
Blynk - FTFC
Thanks !
Now can anyone figure out the double connect messages?
Might be the Blynk.run() you have in the setup? Is it causing any problems?
took that line out… still works… still double connect.
But is it causing any problems? Or is this just an exercise in curiosity :thinking:
By the way… why is this in your setup? I believe Blynk.begin() will already wait until connection.
And another observation… please repost both the serial monitor output an the actual sketch that generated it… you two prior displayed are NOT one from the other, as evidenced in the time printout: If you changed that, what else might you have changed that could generate the 2nd connect msg?
Thanks for the suggestion.
I took out the blink.connect loop and the 2nd connect is now gone.
I still have a problem:
Wake time sometimes (every 30-40 times) goes to over 300 seconds… when it is normally 2-4 seconds.
Here is the updated output.
tail 8
chksum 0x2d
csum 0x2d
v3de0c112
~ld
 Temp :73.40
 RSSI:-43
 **Wake time : 1.93**
tail 8
chksum 0x2d
csum 0x2d
v3de0c112
~ld
 Temp :73.40
 RSSI:-43
 **Wake time : 4.40**
tail 8
chksum 0x2d
csum 0x2d
v3de0c112
~ld
 Temp :73.40
 RSSI:-48
 **Wake time : 302.99**
and the updated code:
// #define BLYNK_PRINT Serial
#include <Blynk.h>
// #define BLYNK_DEBUG
extern "C" {
float tempF;
float waketime;
// how long to sleep between checking TX temp/rssi values - in seconds
#define SLEEP_LENGTH 15
// Blynk auth
char auth[] = "xxxxxxxxxxxxxx";
char ssid[] = "xx";
char pass[] = "xxxx";
  starttime = millis();
  DS18B20.begin();
  WiFi.setOutputPower(0);
  //  while (Blynk.connect() == false) {
  //    Serial.print("atempting Conection"); //Wait until connected
  // Blynk.run();
  Serial.print("\n Temp :");
  long rssi = WiFi.RSSI();
  Serial.print("\ RSSI:");
  Serial.println(rssi);
  Blynk.virtualWrite(11, rssi); //virtual pin V11
  waketime = (millis() - starttime) / 1000.0;
  Blynk.virtualWrite(13, waketime ); //virtual pin V13
  Serial.print("\n Wake time : ");
  Serial.println(waketime);
  ESP.deepSleep(SLEEP_LENGTH * 1000000, WAKE_RF_DEFAULT);  //try the default mode
  delay(100);
  //do nothing here.
  //The Setup() function takes care of it all.
  //as the ESP resets each time after it wakes from deep sleep
Sounds like something gets ‘stuck’ in the Blynk.begin() call.
Glad you resolved your original question.
Blynk.begin() IS a blocking call (until connected).
Search this forum for other topics on Deep Sleep with Blynk… perhaps there might be some suggestions that can be applied to your script.
I am now doing WiFi.begin and it seems to speed things up. (big delays in Blynk.begin…???)
I also had to resort to a sort of watchdog to get past these 300 seconds events…
I now get ‘wake time’ of ~1.9 seconds 90% of the time and once in a while, eit goes up to 2.98 and even up to 4,92 sec.
Watchdog kicks in ~1% of the time. (no connect for >15 seconds) so no big power on for 300 seconds.
#include <Blynk.h>
#include <Ticker.h>
char auth[] = "xxxx7df9c35xxxxx910e242958xxxxxx";
//SSID of your network
char ssid[] = "cxxxxx";
//password of your WPA Network
char pass[] = "pxxxxxx";
int status;
float tempF;
float waketime;
volatile int watchdogCount = 0;
Ticker secondTick;
#define debug 1
#define results 0
void ISRwatchdog() {
  Serial.print("*");
  watchdogCount++;
  if ( watchdogCount == 10 ) {
     // Only print to serial when debugging
     (debug) && Serial.println("The watch dog barks!");
     // ESP.reset();
  secondTick.attach(1, ISRwatchdog);
  status = WiFi.begin(ssid, pass);
  while ( status != WL_CONNECTED) {
    (debug) && Serial.print(".");
    status = WiFi.status();
    delay(100);
  Blynk.config(auth);
  Blynk.connect();
  DS18B20.begin();
  (results) && Serial.print("\n Temp :");
  (results) && Serial.println(tempF);
  (results) && Serial.print("\ RSSI:");
  (results) && Serial.println(rssi);
  //delay(100);
  //delay(100);
void loop () {}
